Results 71 to 75 of 75
June 26th, 2017 11:06 AM #71
Maybe it turns off after 10-15 minutes? ... some sort of delay off? ... Waiting for the facelifted Ecosport ... it has a much better dashboard layout ...
June 26th, 2017 11:39 AM #72
It does not say in the manual. There is even a warning about potential battery drain if you leave a gadget plugged while the engine is off. Will check id I can configure the dashcam instead to auto-switch off if stationery for a period of time. Hassle lang pag matagal naman sa traffic.
- Jun 2017
- 5
September 10th, 2017 12:22 PM #74I use a gopro clone on the righthand side of the rain sensor, it's small and tough enough for the job. Just replace the double sided tape with 3M moulding tape, mine's been there forever (so far). Beats suction cups everytime, just make sure to unplug when you leave coz Ecosport don't powerdown the usb and outlets when the car's off.
Cheers
September 10th, 2017 01:27 PM #75
