Results 1 to 7 of 7
- Jul 2008
- 10
June 15th, 2016 10:00 PM #1Hello, guys! all info will be appreciated.
2012 Ford Everest 4x2 AT Limited Ed. on flat surfaces, reverse is functional & working while in an inclined terrain, it has no reverse at all. brought to FORD, after three days, reverse valve body is the culprit daw.
it got me thinking:
1. is it normal for an almost 4 year old vehicle to have its reverse valve body replaced/rebuilt? average run daily is +-50-60kms on flat paved surfaces with 'pang pamilya' speed.
2. what usually is the cause of the problem in reverse valve body?
3. could this be considered 'major repair' considering a part of the transmission is affected(for a 4year old vehicle)? am starting to doubt ford's 'built tough' philosophy.
thank in advance.
June 15th, 2016 10:17 PM #2
Is the transmission fluid still ok? Is the oil level ok? Any other symptom?
Ford built tough... even toyota is built tough. But chances of failure is always present.
- Jul 2008
- 10
June 15th, 2016 11:11 PM #3yes & yes, ATF ruled out. no other symptoms shown. that is why i am doubtful on the diagnosis that the reverse valve body should be replaced/rebuilt. could it be a misdiagnosed case, maybe some solenoids are at fault. haven't seen the OBD results/DTC.
thanks!
June 16th, 2016 12:58 AM #4
I dont think its the valve body. Its too premature. Solenoid siguro. Get a second opinion from another dealership. Have them read the tcm error codes.
- Jul 2008
- 10
June 16th, 2016 09:25 PM #5sadly dad gave the go signal, they already have brought the transmission down. they also placed the order for a new reverse valve body. need to review the DTC and conduct a thorough interview with the mechs and have them double check the solenoids.
thanks, StockEngine!
have a good one!
- Nov 2018
- 5
January 18th, 2019 06:12 AM #6This doesnt surprised me ... mine is 2017 everest with 19,300 + km. Valve was replaced and was charged php73k
Will be discussing this with our lawyers because we believe the unit has hidden defects considering its almost new. Will file civil case based on lemon law
January 19th, 2019 12:36 PM #7
Not covered by warranty considering that its 2017 model? Also can you pleaae provide more details for the benefit of fellow owners here? A member had his transmission pump replaced under warranty posted in the 2015 Ford Everest thread. I suggest you post on that thread as it covers the 2015 up models.
Hybrids and EV
