Results 71 to 80 of 86
January 14th, 2011 06:09 PM #71
- Jan 2011
- 25
January 14th, 2011 07:54 PM #72
January 14th, 2011 10:16 PM #73
Caltex Delo is designed for diesel engine. pero it is suitable for gas engine din. being designed for diesel engine, high ang detergent nito, meaning, mabilis maging black yung engine oil, so mas malilinis yung dumi sa loob compared to motor oil for gas engine.
hope i was able to answer your question.
- Jan 2011
- 25
January 16th, 2011 07:51 PM #74
Ok I just got the car. The warning light is gone and it seems ok naman. Tried testing it binyahe ko from marikina to alabang to qc and nothing seems to be a problem except parang tunog diesel na ang makina. I dunno if i'm paranoid or what pero is this normal guys? Sorry cause its my first time to use an altis. Thanks.
- Oct 2008
- 85
January 26th, 2011 05:02 AM #76according to many car enthusiasts and blokes, it's because of the vvt system in some ZZ engines (engine used in vios and altis) it gets impressive fuel consumption at the expense of engine oil life.
i personally asked this question to a chemist with a giant oil company in the u.s., he said that most, if not all, sythetics today (SM-rated) should and will last 12 months. for our application (shorter travels) the distance is irrelevant. but he said, 10k kms is even conservative. it can go 15k.
oil spoils daw the moment it gets contaminated, hence the 12 months life. (so store your unused oil in cold, dry places, away from sunlight, etc.)
i change mine every 12 months. 6 years, 6 oil changes after, virtually no oil consumption. i use fully sythetic oil and oem filter.
but for the zz engine-equipped cars, every 6 months.
- Jan 2011
- 25
January 28th, 2011 05:15 PM #77
January 31st, 2011 10:43 AM #78
- Jan 2011
- 25
February 17th, 2011 08:42 PM #79Just an update. Its been 1,700 km since I last gave you guys an update (dami akong pinuntahan with the car).
Today, left my car in the parking mga around 8:30 am then went to work. I came back for my car mga 6:30 pm na then I started the vehicle. When I turned it on the engine warning light (yellow) is kahit naka start na yung car. I thought it was weird so i switched it off then turned it on again. Wala siya for about 10 secs then it came out again. I was worried so I tested the car to check for problems and I observed ok naman. Walang katok, walang drag, my temp is not heating, no sound even, the engine works ok. Na biyahe ko pa from Ortigas to caltex greenhills when I decided to restart the battery baka software glitch lang. I shut down the engine then turned it on again... tas nawala! Waited for 2 minutes just to check then wala paren. So I decided to go na baka electrical issue lang. Mga 1 KM later it lit up again! After hinde na siya nawala. Now i'm gonna bring my car to the mechanic for updates on what happened.
My question is, could it be that this is still part of the sludging kaya? Kaka change oil ko lang 3 weeks ago (used delo oil). And the car works great, binyahe ko na siya sa Clark, Laguna, and recently batangas wala naman problem.
Let's just see what our mechanic would say. Haaaaay. That's it for now.
- Jan 2011
- 123
February 19th, 2011 05:50 AM #80Newbie here guys!IŽd like to share something about fully synthetic motor oil.This is the best motor oil that is available in the market these days.Using this type of oil can prolong the life of an engine,lets say be doubled or trippled engine life compared to merely using mineral oil.Unfortunately,some car owners tried mixing mineral oil to fully synthetic oil or vice versa in their car engines without knowing that it would cause foaming to the oil.Oil foaming is fatal to any IC engine & to your pocket too.Never ever mix them together.Dont be afraid using FS oil,just be aware of what you`ll be adding with.Goodluck
Yes I think those are standard freebies already. You get more freebies if you opt to get bank...
4th Gen Montero Sport (2023)
