Results 11 to 12 of 12
August 31st, 2008 09:45 AM #11
dont expect too much po na may BIG difference sa takbo ng engine because usually psycholigical lang po yan ( smooth ang takbo, mas tahimik etc).
im not saying na walang improvement but what im saying is dont expect too much. unless may noticeable difference talaga yan.
napansin ko lang nung nag change ako into RP (5w-30) mas better ang FC and mas responsive ang engine ng kaunti. pero regarding sa smoothnes ng takbo, is still the same.
IMO
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 31st, 2008 03:22 PM #12with older and very high milage engines i suggest using the thicker weights unless you're ok with the possibility of leaks and replacing the oil seals. if you are then using the thinner viscosity is fine din.
MG4 EV Standard - RWD hatchback with 147mm ground clearance Price: 1.498M More spartan interior...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
