don't reset the ecu unless you know the reason ng MIL (malfunction indicator lamp or check engine light) if it's blinking then iit needs scanning asap there's active misfire, if it's steady not serious enought to kill the cat, but still you need to scan it. try searching the net and you'll find how to read codes by using only a small piece of jumper wire.
