upppppppppp yểm trợ bác
Yun na nga may catch phrase na "whichever comes first". Baka kasi marketing strategy na lang din ito ng mga car brands para mas kumita yung mga casa nila. Ideally, dapat nga siguro palitan ng oil within 5,000 or 3 mos. Pero practical na din ba na palitan na din agad? Natanong lang po.
depende yan bro.
kung 3000 kms pa lang and dalawang bwan pa lang, sayang.
pero kung 4500 kms na, pwede na yan.
use judgement ika nga. one gallon of oil + an oil filter would cost you less than 2000 pesos.
now if you are using a full synthetic oil, pwede yan maski lumampas ng let's say 7500 - 8000 kms.... or let's say, 6-7 months, para isulit mo naman yung cost nung synthetic oil.
pero ako personally, i usually change at around 4800 kms, since nararating ko naman yun at 3 months eh. using a semi-synthetic oil.
lookit the springs, the timing chain and gear..
i think the valve rockers and head are bright, because the metal used has a lighter color..
i have seen mine.. the dry, un-oiled metal is darker than what we see here..
If you have the vehicle owner's manual, just follow the factory recommended oil change and filter change intervals. Be sure to use the correct oil grade for your engine.
If you don't have the vehicle owner's manual, here is a 'general' recommendation:
im no honda fan nor affiliated with honda, but was able to use a honda before k20 engine and i'm a believer that only use Honda Fluids on honda cars!
thats why i like more my toyota 5k and 2nz-fe engine
the oil will not expire, the additives will due to exposure to combustion byproducts (dirt, acids, etc) + air/moistureSame here. I once asked an SA what will happen if my engine oil is still good for 2000 kms but I do not change oil on the fourth month ... ahora mismo MAPAPANIS yung oil?
