Results 41 to 50 of 54
- Oct 2009
- 2,271
February 2nd, 2017 04:56 PM #41
- Jul 2016
- 939
February 3rd, 2017 04:21 AM #42Pa compression test mo all 4 cylinder para maverify loose comp at which cyl.
And then leak down test para makita kung saan nasingaw, sa rings ba, valve, or coolant line...
Google/Youtube mo both term para maliwanagan ka at mekaniko mo(if ever di nya alam gawin yan)
- Jan 2017
- 31
February 3rd, 2017 02:35 PM #43
- Jul 2016
- 939
February 3rd, 2017 11:30 PM #44
- Jan 2017
- 31
February 6th, 2017 03:44 PM #45nilabas ko ulit auto sir. medjo umusok lang nung umandar pero nawala din kahit kahapon wala na.Pero nakita ko na basa yung 2nd na spark plug. Mga half inch yung taas nung basa. Di ko lang sure kung halo ng langis at coolant o tubig. Naalala ko hindi pala napalitan yung spark plug seals nung overhaul.
Hindi naman po kelangan tangalin cylinder para palitan yung spark plug seals? Kung tama po ako yung cover lang tatangalin
- Jan 2010
- 283
February 6th, 2017 04:10 PM #46
- Jan 2017
- 31
February 7th, 2017 09:33 AM #47Noted sir gawin ko sya sa weekend.
Pero naobserve ko sir na di na sya mausok basta level daan.pag paahon lang sya umuusok pag medjo mataas ung daan at mahaba. Lalo na pag babad sa tersera. Pero pag level na ulit daan nawawala na.
try ko ulit saya observe sana mabawasan pa usok
- May 2011
- 481
February 7th, 2017 01:42 PM #48"Pero naobserve ko sir na di na sya mausok basta level daan.pag paahon lang sya umuusok pag medjo mataas ung daan at mahaba. Lalo na pag babad sa tersera."
this is typical of engine oil drain return hole in the cylinder head being plugged up preventing or slowing the return of the oil back to the oil pan. your engine is west-east orientation and the intake manifold side toward the engine compartment firewall. as you described, when going up hill ( oil tends to move toward the intake valve seals) the smoke happens but when you are travelling on level roads and down hill (most likely too) it does not have the symptom.
what you need to do is to open the valve cover and poke/probe all the holes of the cylinder head that is used for returning the oil back to the oil pan. maybe the gasket oil return holes are not big enough and the return of the oil is slow.
- May 2011
- 481
February 7th, 2017 01:48 PM #49also, check your pcv valve hose for oil saturation, it is on the same side (intake) which might be ingesting engine oil without you knowing it.
- Jul 2016
- 939
February 7th, 2017 01:54 PM #50
The 1.5G is good enough for me tbh My current car doesnt even have a rear camera and Ive never...
All New Toyota Corolla Cross
