Results 11 to 20 of 21
October 24th, 2008 11:30 PM #11
Bili kanang cylinder head gasket for that model. Most of the time yan ang problema sa umuusok nang puti dahil may tagas na ang gasket, if not could be a crack in cylider head. So lets hope for the best dahil mahal ang cylider head.
Yong amoy gas naman maaring rich in mixture ang caburador mo(if carburated) or leak in fuel line or due to unburn gas from engine or just need a tune up.
The thing is how old is your car? All of this will come in time dahil sa age ng sasakyan. Bakit hindi mo nalang pa-valve job ang cylider head para malaman kung may crack o wala at gaganda pa ang peformance ng makina.
About Shell mechanic. I dont know kung makakaya nila you just have to found it yourself. Good luck
- Oct 2008
- 469
October 25th, 2008 06:44 PM #12Salamat sir V6dreamer, My ride is 92 eccs.16 yrs old na po auto ko. Kailangan ko pa po ba Palitan rin yung Pistong Ring?? Pagkano po kaya cylinder head gasket??
October 25th, 2008 08:13 PM #13
sa compression tester malalaman kung sa piston ring or or sa cylinder head.. pwede pa compression tester m muna pag pasado and lahat ng cylinder,, check mo yung throttle body ng car mo.. baka kailangan linisin lng po.. sana makatulong to tnx
October 25th, 2008 08:17 PM #14
kung magpapalit u ng piston ring syempre oversize n yan.. dahil may tinatawag tyo trust side and non trust side sa cylinder bore po.. sinusukat yan by inside micrometer caliper po.. mostly mga .25 mm ang dagdag nyan po.. depende kung first 2nd or third repair na po.. and depende din po kung may scored na yung cylinder wall. malalim na gasgas po un... 2 po kasi ang gasgas sa cylinder wall po ridge and scored.. tnx..
- Oct 2008
- 469
October 25th, 2008 11:55 PM #15Pa compression test ko pu muna pala for accurate engine problem identifier? nuh? Merun naman po siguro compression test sa Nissan Commonwealth? Saan po laya my reputable talyer na magaling at hindi mahal maningil for Throttle Body Cleaning sirs?? Very Tnx for ur all responses.
October 26th, 2008 12:08 AM #16
nangyari na yan sa kotse namin. nagpalit ng piston ring, head gasket and valve seal. top overhaul daw yata yun. original parts binili namin kaya nasa 6k. 4k ung labor kasi mahal doon sa shop na yun. pasensya na kasi hindi aq expert.
- Oct 2008
- 469
October 26th, 2008 12:24 AM #17Mahal pala ng inabot?! Pero subukan ko muna palinis Throttle Body. San po kaya shop maganda magpalinis?? pwede po ba I Diy nalang??
- Nov 2008
- 2
November 19th, 2008 07:01 PM #18bosing, yung TC-XL tuwing nagdrive ako, pagumabot na sa middle yung temperture gauge niya bumubuga na ng white smoke, ano kaya problem nito?
THE AUTO SPECIALIST
- Mar 2006
- 607
November 19th, 2008 11:46 PM #19
November 20th, 2008 12:27 AM #20
