Results 1 to 16 of 16
    ...in my Nissan Patrol TD42. Last 80,000km, August nag change oil ako. Last night I check my dipstick, the oil just almost touched the tip of the stick. I checked this 2hrs after I killed (guilty!!!) the engine. Then again before going to bed at around 9pm (early to bed, early to...) which is about 8 hrs. GANOON PA RIN. It doesn't emit smoke, ang lakas hatak, no drip/leak. shell rimula x ang gamit ko. ODO reading now is 81,732 or 1,732 since my oil change.
    My question is, "saan napunta ang langis?"
    BTW, I added 2 liters this morning. Hope to see serious or even crazy/wacky ideas tomorrow.
    I stole it while you were away.
    Sometimes an engine just 'eats' oil for no reason. Ganyan yung long term M3 sa Car&Driver. Ang daming nawalang langis pero walang mahanap na problem.
    Refill and observe na lang. Baka freak of nature lang.
    nangyari din sa trooper namin last year, below the last dot sa dipstick...
    nang ma-drain, tama naman ang laman..
    napa-change oil tuloy ng di-oras.
    dipstick measurement was the same, before and after I started the engine, I was away for 2 weeks and nobody started the engine.
    That does happen from time to time... try to observe first your engine if it will eat up oil again. If it does, then its time to consider the possibilities where its going.
    Happened to our car just last week also... weird. :P
    hindi kaya conspiracy ito ng mga oil companies? meron silang additives na nilagay sa mga oils para unti-unting maubos ang oil, forcing us to refill everytime na mag-check tayo ng oil level?
    Signature
    it's the dip stick! parang etits yan, minsan nahihiya kaya umiiksi. so when you measured the oil level kala mo low pero short yung dip stick kasi shy.
    Jul 2003
    `Nangyari din sakin yan hmmm.... hindi kaya ninanakaw ni otep langis natin. baka naubusan siya ng KY jelly....
    Sa akin, where inaabot ako minsan ng isang taon bago oil change nauubos 2 litres. Mausok na nga ulit si bubbles eh. tapos naalala ko last oil change ko before registration which was january. hehe.
    Ang sagot diyan is oil burns off at the cylinder walls. normal yan for mineral oils, grabe ang burn off kasi uneven ang particle sizes. the smaller particles burn off quickly while large particles remain in the engine. Thats why kailangan ng oil change. Pag synthetic, equal ang particle sizes kaya mas matagal ang interval between oil changes. next palit ko ng oil, i'm going fully synthetic para ok lang na abutin na naman ako ng taon hehe.
    We have the same problem with our Trooper once. We also used Shell Rimula X in the right amount and after a few days halos minimum na sa dip stick. We had the engine checked and everything is normal. Our culprit is the oil. Palit kami ng Castrol GTD at that time afterwards disappear ang oil consumption. Since then minimal na oil consumption. Ngayon Caltex Delo Gold Multigrade ang gamit ay minimal ang oil consumption. Since then din di na kami gumamit ng Shell Rimula X. ;)
    Jul 2003
    Yep, shell ang oil ng car ni ermats, tuwing papakarga siya ng gas, offer ng check yung tao tapos sasabihin kulang oil. so dadagdagan. lagi ganun. shell.... hmmm.... hmmm....
    thanks for your replies. this didn't happened in my gen1 and I used the same type of oil. I usually add oil my gen1 just before my next oil change or about 1/2 liter, pero in this patrol grabe 2liters in 1.7+ km.
    Anong case eto? Unsolved mysteries?
    Sa akin naman after 2000kms. nawalan ako ng 1 liter sa makina after checking the dipstick, bumaba sa normal level ko which is about max of the dipstick. Ngayon malapit na sa 5000kms run, di pa nababawasan.
    Duda ko kulang ang oil na nailagay sa makina nung nagpalit ka ng langis. Better check the oil level a day after you have an oil change, suitable time is after an 8 hour drive. Para nasa baba karamihan ng langis.
    ungas:::may point ka dun. kasi madalas after the oil change hindi natin tinitignan oil level. pero si roydok rimula x din ang gamit. hmmm...pang XFILE ata ito. pag usapan natin mamya. ;)
    As far as i (dont) know, yung difference ng min and max oil levels ng dipstick ay 1 liter. so even if walang langis na umaabot sa dipstick, it doesnt mean na walang oil sa pan.
    Mar 2003
    Nangyari din sa akin ito sa L-200 4x2 pick-up. Dati ginagamit ko ay Mobil synthetic. Pero noong gumamit ako ng Delo 500 para makatipid, after 2k kms. nang i-check ko ang oil level nasa minimum na. Akala ko tuloy blow-by na ang engine ko. Pero ng bumalik ako sa synthetic or mineral, ok na ulit. Ano kaya ang explanation doon?
    Jul 2003
    Mangyan, tingnan mo yung explanation ko somewher here.
    Ano, nahanap na ba and nawawalang pampadulas?
    sa patrol 2 itres ang pagitan ng min at max. 8 litres at min 10 litres at max. thats the advantage of lubricating myself. mas madulas.. ibig ko sabhin, sigurado ako kung ilang litro ang karga. 9 usually lagay ko. Delo 200. hehe kuripot. tapos patatagalin ng isang taon
Where did my oil go?...
