Results 11 to 18 of 18
- Dec 2002
- 39
April 4th, 2003 05:16 PM #11d2 sa may sta rosa/cabuyao/calamba, may murang bilihan ng oil---salbu ang pangalan ng auto supply. but take note na mura compared sa ibang auto supplies d2, pero mas mahal compared sa banawe pricing.
April 4th, 2003 05:55 PM #12
sa may cash and carry. may separate stores over there, they sell motor oils
April 4th, 2003 08:06 PM #13
Merong pong line ng synthetics ang Petron at reasonable prices. Just visit your nearest Petron sation.
Tsikot Member Rank 3
- 400
April 5th, 2003 12:04 AM #14I've tried fully synthetic and I've tried synthetic blend.
In my opinion, the price differential between these and
mineral based oil is not justifiable in a practical point
of view. Mas lalo na ngayon na sobra ang itinaas ng
presyo ng gasoline at lubricants na rin.
So habang mataas ang presyo ng motor oils, bumalik
uli ako sa mineral based oil. Di naman ganun kalaki ang
difference sa performance at tutal naman after 6 months
change oil ka na naman din...
20W/50 API SL, ayus na yun. Sa panahong ito, dapat maging
practical...
- 3,754
April 5th, 2003 10:53 PM #15Ako ever since fully synthetic gamit ko, I notice talaga yung fuel consumptions at smooth hmmmm ng engine. Medyo magastos lang talaga
- 197
April 6th, 2003 01:39 AM #16If you don't drive your car hard, race or use them regularly in poor environments, or if the owner's manual doesn not specifically tell you to use full synthetic oils, forget it, its not worth it.
Ultimately, the biggest benefit of full synthetic oils is that they can operate at higher temperatures without chemically breaking down / boiling.
April 6th, 2003 03:48 PM #17
compute na lang kayo kung sulit ang semi-syn or fully syn sa ride nyo(daily driven)...
ako di pa tapos sa ginagawa ko pero malamang magbalik ako sa semi-syn...very little ang na-gain kong fuel economy(using RON95 fuel) when i switched to fully synthetic engine oil pero makakatipid naman ako sa oil filter...compute pa ako... :|
mineral vs. semi-syn/blend vs. fully syn
consider the following:
1. labor cost-CASA, DIY or gas stations
2. oil filter-replacement or OEM
3. fuel savings-km/ltr and cost per liter
share nyo na lang sa amin :wink:
- 197
April 6th, 2003 03:56 PM #18By the way, my mechanic recommended me to stick to just one brand of engine oil and one brand / type of fuel for your car. This is so that the engine will get used to the oil / gas you use, and it takes several cycles of full-tank fill-up and oil changes before you get any noticeable benefits for your engine.
