Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2006
    i've searched the forums and read about the problems arising from low idling.
    but i only see poor fuel consumption as the problem kapag mataas ang idling ng kotse.
    natanong lang sa akin, and i don't know what to answer.
    thanks.
    Jul 2006
    Well the moment you engage first gear you will wear the clutch (manual) or the clutch packs (automatic) if the idling is too high. That's the first thing that comes to mind.
    atleast it gets your battery better charging... I think...
    Aug 2007
    takaw sa gasolina
    matakaw na sa gas maingay pa
    May 2007
    Quote Originally Posted by wewoy_romero View Post
    thanks.
    maybe the Linkage and throtle are dirty (clean it)or the timing is high. Also inspect all vacuum hose for crack and clean all the oropice baka barado.
    Nov 2003
    is it high idling or low idling you are asking about?
    kung low idling then it will result in a lot of vibration in the cabin.
    Apr 2006
    high idling.
    my neighbor's car (same as mine - civic 98) idles at 1k with aircon and headlights on. sometimes at 1.1k. i mentioned it should be around 750 to 850. he likes it as it is daw.
    he then asked me ano daw ba problem dun. all i can answer is high gas consumption. he said, di ba it only matters when the car is standing still? pag umaandar naman na daw, it's the same for all whether the idle rpm is high or low. kung madalas daw naka-steady (sa traffic etc), then saka lang daw magma-matter yung high idle.
    di ko siya masagot because it makes sense to me.
    first of all, if the car's engine cant stay running at factory idle, then there's something wrong with it.
    Band aid solution lang ung taasan ang idling to keep the engine from dying.
    Nevermind the obvious --- increased fuel consumption in city driving
    How about wear-and-tear ng makina? That explains moderate mileage cars with bad engines
    plus the heat generated pag high idle while the car is standing still when little air is blowing past the radiator like when ur driving...
    all those underhood parts being cooked while the car is standing still at high idle...
    minsan ginagawa ng mga A/C technician tinataasan ang idle para lumamig ang A/C...
    It could mean accelerated wear on the engine.... Maybe still under tolerance, but the car should have been designed to run idle at certain RPMs... Higher gas consumption..
    Also, I almost forgot (I think not yet mentioned here),- hard on the brakes...
    5101:pcwhack:
    mahina na kasi ung air compressor kaya binabawi nila sa rev.
    palitan nalang ng bagong compressor
    Nov 2003
    with the amount of traffic here, he is wasting a lot of gas. pero kung ok lang sa kanya then let it be
    May 2007
    high idling means mataas kesa sa normal idling, mejo lakas sa gas ng konte kase di normal idling reason bkit mataas, check kung naka tune ang makina.. make sure na naka tono ang makina ng maganda para maibaba sa normal ang idling.
    Oct 2007
    high idling.
    It is wear and tear for nothing, there is just no use for it (high idle)
    sabihin na lang natin na mas mabilis ng 20% ang pagtanda ng car nya when idling.
    Oct 2007
    wag na kayo bumalik doon sa technician na iyon pag ganyan, hindi marunong yon
    How will you know nga pala if your idle is in the right setting?.
    TIA!
    usualy, may sticker nalalagay sa engine bay sa RPM setting. considering kung may tachometer sa dash...
    Oct 2007
    Quote Originally Posted by drey View Post
    TIA!
    Meron din sa body tags, yon plate na meron body no#, engine no#.
    Minsan metal sticker lang sa may cylinder head cover.( recommended rpm)
    Mararamdaman mo naman na hindi sya mag stall at hindi rin fino andar. tamang tama lang para di mag vibrate engine.
    Apr 2006
    well whatever suits him. it's his car naman, not mine
what's wrong with high idling?
