Results 1 to 8 of 8
- Jun 2011
- 26
August 9th, 2011 06:11 PM #1Good day to all,
this is what happened to me last week.
Car: Nissan Sentra Series 3 1996
Given: Newly change battery, sparkplug, & ignition coil
while cruising (aircon on), I felt that my engine was about to shutdown because whenever i stepped on the gas it feels like the gas isn’t working even though my foot is already on a full press (its like my ubo yun kotse). After a while the engine died and the car had a hard start, what I did was I let the car rest for seconds then started again. The car started however when I turned-on the aircon the car was about to shut down again so turned-off the aircon and got home.
Mga Sirs, here’s my question:
1. What could be the problem of my car is it about the aircon, Fuel filter, Oil pump etc. or distributor?
2. Any recommendations for repair or shops?
Your reply will be greatly appreciated.
Maraming salamat Tsikot!
- Nov 2009
- 6
August 13th, 2011 09:32 AM #3
Could be a problem with the aircon compressor. It might be difficult to turn because of a wear & tear with its bearings or internal parts.
August 13th, 2011 11:10 AM #4
car engines never die. they stall! sounds like you have a problem with the ignition system. is your ignition coil located in the distributor? is your ignition coil showing signs of high voltage leak characterized by white traces around the ferrite core? have your ignition evaluated first. don't take guesses. have the results quantified (there has to be numbers not guess feeling)
- Jun 2011
- 26
August 15th, 2011 12:43 PM #5mga sirs!
maraming salamat sa mga post ninyo... natutuwa ako sa mga post ninyo kasi nun pinacheckup ko yun auto ganyan din sinabi (lalo n yun aircon) i just couldnt imagine, malaki pala ang epekto ng sirang aircon sa kotse... ang kailangan ko na lang ay pera pang gawa.. ipon mode muna...
mga sirs, sana hindi kayo magsawa mag post o sumagot ng mga inquiries.. Many thanks again and thanks to tsikot..!!! I LOVE this site!!
- Jun 2011
- 26
- Apr 2011
- 11
August 22nd, 2011 11:07 AM #8hmmmm? tingin nawawawalan ng supply ng gas..cause nyan barado na ang fuel strainer mo kaya nahirapan humigop ang fuel pump mo..or tumitiklop na yang fuel strainer mo dahilan ng pag bara sa fuel pump mo kaya wala syang ma higop na gas. walang ibang problema ito kondi ang iyong fuel pump, or baradong fuel strainer..palitan mo lang yang 2 yan solve problem mo wala ng iba
