Results 31 to 40 of 152
- 237
October 13th, 2002 01:52 PM #31hey suntzu!
nice to see you here!
guys
nakabili na po ako ng oil para sa LONG OVERDUE na change oil...whew...buti napilit ko na dad ko....first im looking at havoline...pero mahal...so i settled for castrol gtx ata un...490 for 1 gallon...1 gallon na binili ng dad ko so may pamalit na ulit...whew...
niw..i know its bad for your engine if you put additives...ano ba side effects nya?
my dad kasi i still using an additive...i thing its cyber lube...gawang pinoy...sabi nya, may isang chemical ata na wala sa cyber lube...un daw ung chemical na present sa ibang addtives at un daw ung nakakasira at nakasasama sa engine...
palagay nyo?dapat ko pa bang palagyan?
October 14th, 2002 09:45 AM #32
Mobil Delvac for my diesel fed engines. :D
I know an outlet near Earnshaw in Sampaloc that sells Havoline oil for 110/liter.
With regards on oil additives, better think twice before using it, does your car's engine require extra effort to haul heavy loads? If so, go on with a branded one. :D
- 36
October 16th, 2002 01:17 AM #34I tried using Idemitsu Fully Synthetic... mura for a Fully-Synthetic oil kaso wla ng mabili kaya I switch to Havoline Energy
- 370
October 16th, 2002 09:17 AM #35Better than Mobil 1 synthetic, according to my brother who gets 9km/l when he uses that compared to 8.2-8.5km/l when he uses Mobil 1 synthetic.
For our purposes, it kept the temperature on our previous turbocharged rally car more stable.
Previous oil used would bring engine temperatures to about 7/8 of maximum after a couple of runs.
After switching to LiquiMoly with Molybdenum DiSulfide, engine temperature was constant at minimum operating temperature, even after 12 back to back repeated runs.
We've been using it ever since on all our vehicles.
It's made in Germany, is a mineral based oil, altho LiquiMoly also has synthetics.
It's 250/liter & available from me.
- 67
- 152
October 22nd, 2002 12:05 PM #39[size=12][size=9]fuchs sakin... 112.00/L k naman sya.[/size][/size] :wink:
And you can't opt out of the update.
National ID Law
