Results 51 to 60 of 75
- Jan 2007
- 2,229
September 6th, 2021 03:22 PM #51My covid runabout got its oil changed just before our first lockdown March last year. Up to now hindi pa na oil change ulit, pero malapit na.
Roughly 4300kms in 18 months.
September 6th, 2021 03:38 PM #52
I changed the oil of 2 of my cars after 16 months and < 1TKm run. Have to change the oil on another one that has even less usage at 18 months and ~300 Km run.
September 6th, 2021 04:13 PM #53
Mine's a Diesel vehicle. I don't think 1-2 months will make much of a difference on the Diesel fuel inside the tank. After doing some reading online, it appears that Diesel would last a minimum of 6 to 12 months in a typical fuel tank.
Mas mabilis mapanis gasoline.... 3-6 months.
It's not to say na hindi na aandar yung car with a 3 or 6 months-old fuel. Pero definitely, degraded na yung fuel. YMWV.
- Jan 2007
- 2,229
September 6th, 2021 04:21 PM #54Does it sludge or turn milky? If it doesn't then AFAIK if you're on synthetic and your low mileage car is garaged (not exposed to moisture from weather etc) the oil will last a while.
Stop Changing Your Oil! | Edmunds
I have another car that's been garaged at condo. Not even 1000kms since last oil change with Motul full synthetic two years ago. I'm planning to take a sample of the oil and send it in for analysis before I decide whether or not to change.Last edited by Dr.Kamiya; September 6th, 2021 at 04:23 PM.
September 6th, 2021 05:57 PM #55
Not sure what Nissan used in my last oil change at the dealer so I changed it with FS last time. The Honda had FS from the dealer but that one was 0w-16 and from all the cold starts since the lockdown I was worried about shearing from fuel dilution.
Do you bring your samples to Monark? How much are the tests now?
- Jan 2008
- 4,726
September 6th, 2021 06:03 PM #56
- Jan 2007
- 2,229
September 6th, 2021 11:36 PM #57
September 15th, 2021 06:34 PM #58
September 16th, 2021 12:51 AM #59
For those interested for a Fumoto valve:
Fumoto Engine Oil Drain Valve F1 6S with Lever Clip
Ask the seller when it will be available so that you can buy it once there's stock.
- Jan 2008
- 4,726
September 16th, 2021 10:52 AM #60
Monk-owned R53
