Results 1 to 14 of 14
    Aug 2006
    Hi need help my civic Vti sparkplug is burning oil one sparkplug lang naman.
    Problem is that i already replaced valve seals a year ago and before naman di ito problem even before replacing the seals. My mechanic wants to replace the valve guides feeling ko kasi palpak ang kabit ng valve seals kaya ganun.
    Hassle kasi that all the parts i bout last year will now be replaced again e.g. Cylinder head , valve cover gasket, intake manifold gasket etc....
    TIA
    Sorry kung there is a theread similar to this. Have been searching for answers sa site but nothing similar to my situation.
    Sep 2009
    baka piston ring yan paps kung isa lang ang nagsusunog ng oil????
    Aug 2006
    Yup isa lang pero sana wag? Any other had same experience? Pero ang mileage is aroun 115 k palang no history of overheat
    Jan 2012
    kung madaling mangitim ang oil mo ,possible piston rings na yan
    Aug 2006
    Just did compression test reading was 100 on all pistons wierd lang reading other posts reading nila 120 plus plus valve guides na kaya ito
    Sep 2009
    teka nga po.. pano mo nga po pala nasabi nagsusunog ng oil yun isang chamber?
    Aug 2006
    Basa sparkplug ng 1 chamber
    Jul 2003
    Quote Originally Posted by Cobalt Blue View Post
    saan side yung basa? yung tip na nag-iinite or yung tip na nakakabit sa high tension wire?
    Sep 2009
    kung yun tip ang may oil,,possible din cylinder head gasket yan,, yun sira is natapat sa isang chamber kaya dun lang ang pasukan ng langis..
    try mo paps, alisin mo yun sparkplug,, then pasukan mo ng stick na may balot ng malinis na puting basahan. then ipahid pahid mo luob ng chamber para malaman mo kung pati sa luob ng chamber eh may langis. kung basa man check mo kung langis....
    Aug 2006
    Sige try ko yun pero cylinder head ko bago na rin pero replacement eh. Salamat
    Mar 2007
    mga sir ganyan din po sakin...apat na sparkplug po yung sunog...kulay itim po yung tip.after a day pinalitan ay sunog n nman yung apat...kumokunsumo ng langis kc ambilis maubos ng engine oil at amoy langis yung lumalabas sa exhaust at ang daming carbon ng dulo ng pipe...anu anu po kaya ang mga ipapaayos d2???anu po kaya ang may singaw at tagas sa loob???sabi po kc ng mekaniko ay baba makina at papa machineshop na daw at overhaul...abutin daw ako ng mga 40k...newbie lang po ako here at honda 98 crv po yung car....thanks!!!!
    Jun 2005
    Quote Originally Posted by maxymaxy View Post
    pacompression test ka muna... then kung mababa talaga reading, then you consider overhaul. have you changed air filters and throttle body cleaned?
    personally, pacheck ko muna sa speedyfix kasi gamay nila ang honda
    Jul 2003
    kamahal naman ng overhaul ng CRV.
    kuha ka ng needed parts tapos canvass ka.
    tapos tanong mo na lang yung labor ng mekaniko.
    kung ok pa piston mo at walang tama ang sleeve, baka makaligtas ka sa machine shop.
    yung valve guide, sa machine shop din pag nagkataon. mahal pa naman magpa machine shop.
    Sep 2010
    * cobalt blue, sir anu na nangyare sa car mo?na overhaul npo ba ang engine? Anu ang pinagmumulan ng wet spark plug? Medjo same prob tayo. Thanks
Valve seals or Valve guiides
