guys, what is the best way to relieve fuel tank pressure? the pressure is great that the cap cannot be remove if you close the cap tight. even when not tight, when I remove the fuel tank breather pipe, I will hear vacuum.
Both ends of the breather hose seems NOT blocked. because when I tried to blow air to it. I hear air passing either ways in or out.
I already switch the cap from another same ride, but same problem. the other ride seems working fine with the suspected cap.
any solutions?
I read that one solution is to drill hole in the cap. but is it really safe? a fuel singaw from the fuel cap hole seems dangerous.
Kala ko gasolina
