Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Question po everyone, I understand importante malaman ang mileage ng cars (lalo na kung bibili ng second hand) pero gusto ko po sana itanong ang mga sumusunod:
    1. Ilang kms po ba ang acceptable mileage ng car para masabi na ayos pa ang engine cya?
    2. Ano pong mangyayari kung sobrang taas na ng mileage nya?
    3. Enough po ba na well-maintained ung car - such as change-oil and regular tune up para ma-off set ung fact na mataas na ang mileage nya?
    4. Any more tips para sa engine and mileage? meron po bang rules dito?
    thanks!!!
    Aug 2004
    - Depends on the car's age. If I am not mistaken 10,000 km per year ang standard. Warranty wise ito ang tinitignan ng casa.
    - As long as it doesn't look laspag and it still looks fresh inside and out and it has service records then it should be fine. Kung hindi maintenained and alaga ang high mileaged car makikita mo naman sa pagtingin pa lang sa una.
    - For me, yes. High mileage doesn't mean it is more prone to breakdowns. Usually based from my experience, the high mileaged car is much more reliable than a low mileaged car.
    10,000 per year sa pagkakaalam ko. Just check for service record and the history of the car. My bayaws car is only 26,000 km but natirik na kami most of the time. My car is 80,600++, never been tirik because when I acquired the car I checked for the service record of the owner, called the casa and I am maintaining it very well. Swerte ko lang din siguro.
    thanks!!!
    Aug 2004
    There are so many factors that it's almost impossible to say.
    Typically, you want an engine that:
    has never been started in a cold environment (cold startups cause most of the wear and tear on the engine)
    has never been driven less than 50 kilometers a trip (frequent short trips are bad, as cold running wears down an engine... and more short trips equals more cold starting)
    has never been in traffic (heat soak is bad for the engine)
    has never been left to idle for long periods
    and has had synthetic oil every change since the break-in
    In other words... it's impossible to find a perfect engine.
    Whatever the mileage of the engine, you have to check the running condition, which means it should idle well, rev freely, not eat oil, not have high emissions, etcetera.
    I've seen lots of engines that have needed an overhaul between 60,000 -100,000 kms, but others have kept on going. Our Crosswind is at 120k, and is perfectly fine... missed a few oil changes, but at least we've changed regularly. Our Highlander is at 140k and it had to have headwork, because oil changes were few and far between.
    If you're really good to your engine, it could probably hit 400,000 kms before needing an overhaul... but with our local traffic, it's doubtful. I'd say 200,000 kms would be more realistic.
    This is tricky territory.
    High milage is not much of a concern as long as the engine has been properly maintained and used.
    If it was poperly maintained and used, more often than not, all the parts that will need replacing have already been replaced.
    niky and hyperthread bring up a lot of valid points in their discussions.
    Like I said in another thread, buying a used vehicle (high milage or not) is pretty much a crapshoot unless you know the owner and know that he/she REALLY took care of it and is familiar with the history of the vehicle in question.
    Hope this helps
    I once drove a L200 in the province with nearly 200,000kms... oil changed regularly and it was driven on the highways lot; it felt and drove much better then a similar age and type L200 i drove in Manila with less than 100,000kms.
    our 2nd owned '96 corolla GLi ae101 already has 212,+++ kms on it, pero it was never overhauled yet, timing belt replaced thrice already, (was replaced at 60,000kms, 135,000kms and 202,000kms.). still using the original alternator and a/c compressor. walang usok that signifies worn out seals, and still runs very well. we knew the previous owner who regularly brought it to as far as pagudpud up north, and camarines norte down south. and it was his daily ride since it was new.he religiously maintained the engine with regular oil and filter changes, and followed the schedule for other parts as well. don't know how many times he replaced his tires though
    sir high mileage doesn't necessarily mean that the car is in bad shape. what matters is how well it was maintained and driven.
    Quote Originally Posted by chon961 View Post
    thanks po! just text my friend now (the first owner) kung napalitan na ung timing belt ng oto, pero sabe nya, timing chain daw po ung sa sentra ko, ano po ang difference? thanks!!!
    Aug 2007
    ^ Chon961, what you said there is very true. How well an engine was cared for by its owner is more important than mileage.
    Plus the fact that a lot of pre-owned vehicles do not show the 'real' mileage of the car...its quite risky if you do no know the owner.
    Quote Originally Posted by macychic View Post
    naka timing chain nga ang sentra bro hindi masyadong kailangan ng maintenance nito compared to the rubber timing belt ng mga toyota, honda, mitsu at iba pa na kailangang palitan around 80,000-100,000 kms. anong model ng sentra? as far as i know yung ECCS/LEC body (B13) at yung series 3 (B14) gumagamit ng timing chain.
    ang alam ko hindi naman kailangang palitan ang timing chain, unless sobrang ingay na nito, pero hindi ako masyado sure bro, ha. let's wait for the replies ng ibang mga tsikoteers
    Quote Originally Posted by DonT View Post
    yup bro, that's one of the most common problems concerning a car's mileage. that's why "low mileage" cars that are for sale don't really catch my attention, but if i know the owner, and i'm really sure that the car has its real mileage on the odometer, then that car deserves a second look
    Aug 2005
    50? di ba 5.0 Km?
    Aug 2007
    Do you guys really think na we also have this "cold starting" phenomena. Maybe in baguio, but in most places in the PI, temperature only drops down to maybe 23 or 24.
    Before I go OT here..it would be hard to determine if a pre-owned car has been through a lot of short trips where the engine has'nt really warmed up yet. Knowing the owner helps (check the distance from his residence and work place might help).
    mileage (high/low) is not a big deal sa mga 2nd hand vehicle. gaya nga ng sabi nila nadudugas na odo ngayon keanalog or digital pa yan...makina na lang makapagsabi kung okay pa ito.
    magsama ka na lang trusted mechanic para tumingin sa sasakyan. konting silip at konting katok lang katapat nyan.
    goodluck bro.
    For me, buying a used car has always been a game of chance. Niky is right, there is no perfect engine and yes the first overhaul can come in the hundred thousands like in most Mercedes Benzes.
    Even if I tagged along with me the best mechanic I know and gives me the thumbs-up to buy the car, there will always be at the back of my mind some doubt because we will never know the real state it is in until we actually get to drive it on a daily basis.
    Nov 2003
    have the car checked by a mechanic before you buy it so you get a gauge on what you need to spend on. if the seller is decent naman he will be ok with the checkup since wala sya itinatago sayo.
    Another thing.
    Most of the people I know prefer to buy from Doctors because most of them have more than 1 or 2 cars in their stable. Pero di ba meron din mga doktor na poor mag maintain ng car?
    Jan 2003
    Quote Originally Posted by grantt View Post
    Yep I agree. Ive seen an ad from another local auto website. the poster claims he can adjust the odometer; digital or analog. nakakatakot. so getting a low-mileage car is still not a guarantee of trouble free driving.
    one of the ads of toyota is about reliablity.on the ads, some of the corollas has 300K, 250k on their gauge but still on good condition.
    Mga bossing,
    ask ako pala, how do you determine i the odometer has been tampered? Be it analog or digital. thanks
    Aug 2004
    50? di ba 5.0 Km?
    Hehehe... sigurista ako kasi.
Question re: Mileage and Engine
