Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    May 2004
    This evening I try to check my oil before starting my engine. I notice that its not in the right level. Then I started the engine and open the oil filler cap and notice smoke coming out. smoke also come out in the Dipstick while the engine is running. and there is a sound like somebody is using a type writer. What could be the problem? 4bja1 engine...
    BTW can somebody point me a good diesel mechanic near San Juan, shaw blvd area. thanks...
    May 2005
    Quote Originally Posted by 1997 View Post
    Timing belt po ba yan. Nangyari sa amin dati e nag-slide ang timing belt namin na naging cause ng pagsala ng timing kaya nag tunog type writer din po sya.
    May 2004
    Quote Originally Posted by kokey View Post
    Timing gear po...
    Jul 2006
    Not sure about the specs of your particular engine but if a valve adjustment has not been done recently, it probably is time.
    May 2004
    Quote Originally Posted by mbeige View Post
    I plan to do that today... sana hindi malala yung problem ko... Wala naman po aoil sa radiator... hindi din po maitim usok sa tambutso...
    Jun 2004
    Smoke coming out of the dipstick sounds serious.
    How many km have your engine run?
    Malakas ba sa oil (more than 1-liter/5000km)?
    You just started the engine.
    Cold pa siya and hasnt expanded yet. The piston rings hasnt flexed to give a tight seal. You havent given it load and sufficient RPM.
    Try it again if it has reached normal operating temperature.
    One more!
    Put enough oil first.
    Oil is important for sealing compression gaps.
    May 2004
    Had it check to 3 different mechanic.. all diagnostic leads to overhaul... and it will cost more or less 20K... What parts to be replaced when overhauling? Can you give me advice on where to get an overhaul? preferably San Juan shaw blvd area... thanks...
    Sad thing is I bought this car 2nd hand and it did not emit smoke during our inspection... and I really don't have the money to have it fixed...
    Consume less than 1 Litter for the span of 3 months or 3500KM...
    Think positive!
    Mechanics should not make a call of general overhaul until they have atleast removed the cylinder head. For what you know baka c.gasket, valves, valve guides and seats.
    Jul 2006
    The threadstarter did not indicate whether it was a cold or warm start, but yes, Tootsie you're right about warming it up first.
    Jun 2004
    If it is not yet drinking oil (<1liter/3,500km is normal) then it is not yet critical. I have known of engines consuming oil at the rate of 1-liter per week and still work ok. Diesel engines are sturdy and even at your condition it will still run a long time. If it is not belching thick smoke, overheating, losing power, etc, then you can wait until you fail the next smog test. I had a Gemini(diesel) before and we only overhauled it at 200,000km mark. It ran fine even before the overhaul - maingay nga lang (parang sobrang lakas na typewriter). And mausok lalo na kapag accelerating furiously - pero baka naman dahil sa worn fuel injection.
    Mechanics will naturally tell you to do an overhaul since that is how they make their living. Magkano na ba ang labor ngayon - P5T (or more) for a few days of overhaul work.
    Bottom line, you can wait, plan and save-up on the overhaul. In the meantime, you can have the valve clearance adjusted, check the timing, and maybe use oil additives. And continue monitoring your oil - check it every morning.
    Or to have peace of mind, do a compression test. It may just be worn valves or guides.
    How many kilometers have your car done?
    May 2004
    Quote Originally Posted by calcite View Post
    Sa totoo lang po it runs fine... no black smoke... Only white smoke... No trace of oil sa Radiator... No overheat or water loss... Maganda pa po ang hatak... My AUV has 113t KM on it... I'll monitor oil loss and have my valve clearance to Manufacture specs... Thanks... any more comment or suggestions? Really would appreciate it... TIA
    Jun 2004
    113t km is nothing for a diesel engine - specially Isuzu diesels. For comparisons I bought a 2nd hand L200 pickup with slight smoke coming out of the dipstick. I used it for 5 more years and it ran fine. Just had to re-calibrate the injection pump to lessen the smoke emissions and pass the smog test.
    Just monitor your oil consumption and the smoke emissions. And watch out for the smog police on Edsa - but that is true for all diesel engines in metro manila.
    Mar 2005
    Same yan sa isuzu pickup ko, meron white smoke kung buksan mo oil cap at dip stick. Specially mangyayari kung cold ang engine. Sabi ng senior mechanic ng Isuzu na kilala ko. Normal yan. As long as walang masyadong talsik ng oil (bigger ng pentel pen size at di nagbabawas nang oil, di yan kelangang i-overhaul. Nira-racket ka lang ng mga mekanikong pinagtanungan mo.
    Pa-adjust mo muna valve clearance.
    May 2004
    Quote Originally Posted by Hibiki View Post
    Salamat bro... La naman tumatalsik na oil... tataka lang ako overhaul na rin suggestion nila... Cguro pa adjuct muna ako valve clearance then pa compression test ko na rin.
    Tatakot lang ako kasi madalas sakay ko GF ko and nakakahiya masiraan... hehehe...
    Nov 2003
    if it runs fine then don't touch it nalang imo. leave it alone till you really need to have the engine opened.
    May 2004
    Quote Originally Posted by speedyfix View Post
    It runs fine... but the only thing that anoy me is that tick tick sound... parang metal to metal scratching... I really need a good Diesel mechanic that Knows isuzu engine... Anyone? thanks...
    Jul 2006
    It's probably the right time to get a valve adjustment done like I said earlier. The valves might be too tight na.
    May 2004
    Tama po ba na valve adjustment must be done when the engine is cold?
Diesel Engine help(smoke on oil filler cap)
