Results 31 to 40 of 86
February 6th, 2010 12:06 PM #31
Guys and gals it is against the law for ANY gas station or automotive fuel provider to supply fuel with ZERO ethanol. The Bio-fuel law made sure of this. I don't think it has been amended or repealed so it remains.
Simply put, all pumping stations have been provided with 2 to 10% ethanol mix by their suppliers since 2006 and by 2010 August all as in absolutely ALL will provide E10 (or 10% Ethanol by volume) fuel.
Research na lang ninyo Biofuel Law. So far Blaze has the least ethanol pero by 2010 August lahat E10 na.
Here's the even worst development. Pinagiisipan na rin ang E20!!!!
If a law is passed on this, by that time all carb engines would have died out already or have been replaced/adapted?
If you cannot find any non E10 station, that is because the Biofuel law made sure of it.
- Jun 2009
- 11
February 6th, 2010 04:39 PM #32Unioil and Jetti wala pang ethanol sa gasoline. I called up last night.
Kung lahat tayong mga owners ng lumang sasakyan eh magsasalita, sasabihan ang mga kongresista natin, gagawa ng letter to the editor sa mga diyaryo, magtetext sa mga radyo at TV stations -- siguro naman may makikinig sa atin tungkol sa hinaing natin sa ethanol na yan.
Si Zubiri ang father of the biofuels law.
February 6th, 2010 05:46 PM #33
Sorry. Correction. Wala pa palang halo ang isang fuel ng Flying V. Unleaded lang pala.
Yes, si Zubiri ang father niyan. Walang pakielam, dahil e-10 compatible naman ang kotse niya.
- Jan 2005
- 445
February 6th, 2010 07:27 PM #34Kung E-10 lang, wala namang problema sa carbed engines na nahawakan ko .
I've been using unleaded e-10 for 2 years na (toyota 4k engine), di naman tumagas ang fuel line ko or nag corrode or nasira ang fuel pump ko, same with my sister's lite ace (5k engine). My brother's toyota 12r is using e1- unleaded for 3 years now.
Yung alcohol kasi instead na mag corrode eh, inaalis nya pa ung water sa fuel mo.
Kung e-20, ibang usapan na yun, kahit injected magloloko dun.
As far as I know, halos walang rubber components ang carb, except for the plunger.
- Feb 2010
- 20
February 7th, 2010 09:14 AM #35My engine is 4g63 carb type 2.0 l300. Almost 3 yrs nko used ng e10 paiba-iba pa nga gasulinahan. La me nakitang kakaiba. My fuels lines are intact same w/ my carb. I have not yet overhauled my carb since i used e10. 4 me theres noting effect using e10 gas. hindi ni ilalabas ang e10 kung mkkcra ng marjority car owners s ating bansa.
February 7th, 2010 09:30 AM #36
^ Actually. You guys who aren't experiencing problems with e-10 gasoline is lets say, the luckiest. Majority of the owners of the vehicles in which in their engine is carb type is experiencing sudden changes with their car performance. Why ? I don't know. I haven't tried e-10, yet.
February 7th, 2010 11:44 AM #37
You might be lucky because my 1999 Corolla GLi developed a pin hole leak on the fuel return line, causing it to spray gasoline inside the engine bay. I was just lucky that it didn't catch fire and that I can disable the gasoline system and use LPG until I had the faulty tubing replaced.
February 7th, 2010 11:47 AM #38
- Apr 2008
- 537
February 7th, 2010 04:00 PM #39
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
