Results 31 to 40 of 55
July 2nd, 2004 09:44 AM #31
LORD Vinj
Baka kasi magkaiba tayo nang Diagnostic tool.. pero tama ka rin po.. reset lalo na pag error code pero dito po sa amin medyo critical ang error codes bago ireset hehehehe
ARB - AMEN ako sa yo diyan
July 2nd, 2004 02:02 PM #32
just got back from nissan casa. the culprit was the Mass Airflow Sensor. pinalinis ko na ito around 3 weeks ago. pero bumigay na daw. so pinalitan na. P8,200.00 ang cost.
nilinis din yung Turbo Pressure Sensor just to be sure. since 91,000 kms na ang tinakbo ko, they also recommended to clean the intercooler and all the tubes connected to it.
ngayon nawala na yung check engine light and i can drive pass 120kph. umabot ako kanina ng 140kph. what i like to try is to reach 165kph kasi the past few months, hanggang 150kph lang ako.Signature
Tsikot Member Rank 5
- 3,144
July 2nd, 2004 02:29 PM #37
that's very good news boybi... :D mahal din pala yung air sensor na 'yan... at least you won't have to change or overhaul the injection pump since that would've been more expensive...
nakahinga din ako with regards to my own gu patrol... ehehe...
July 2nd, 2004 03:02 PM #38
i think ang nakapagpasira sa Mass Airflow Sensor ko is the Finer Filter i installed. since meron oil yung filter, baka meron na higop na konting oil then napunta dun sa sensor. according to the service technician, yung sensor tip daw ay umiinit at namumula kapag naka ON ang engine, pagkahigop ng air, nababawasan ang init nung sensor, this change in temperature is translated to a change in voltage that is sent to the ECU. before the sensor was replaced, the voltage reading of the sensor is below 2V. after changing it, the voltage reading is from 2V to over 3V depending on the engine RPM.
Signature
July 2nd, 2004 03:56 PM #39
sakitin talaga maf sensor ng nissan... mga sentra at cefiro maf sobrang sensitive dn
July 2nd, 2004 10:24 PM #40
where is the MAF located? before the breather hose from the engine, after the turbo or its the last one before the intake manifold?
if its the last one, there is oil coming formt he breather, it will also contaminate the MAF.
yung akin naman... you can add the reverse cam and back-up sensor... pero ADAS - I don't think...
All New Toyota Corolla Cross
