Results 1 to 11 of 11
    Jun 2008
    guys, my 2000 kia carnival's turbo gave way. may shop ba kayong alam or selling surplus. thanks
    Sep 2006
    Quote Originally Posted by cruz8101 View Post
    Try some stores in Banaue which specialize in Korean surplus parts.
    By the way, you have to find out why your turbo failed. The same failure could happen again if the root cause is not corrected.
    try speedlab sa quezon avenue, tapat halos ng Pegasus. they are familiar with turboes.
    Jun 2006
    Were you practicing the 2-minute idle before turn-off (after a long run) method to preserve the turbo?
    my dmax have a turbo, i often run long distances (nlex) at quite a high speed than average, it has logged 120,000+ km in 4 years, and i never had turbo problem... may be its the quality of the brand -- can't expect so much from KIA OR
    its plain old age (its an 8 year old KIA).
    may tumatagas ba na oil sa turbo mo? umuusok ng grabe ba on idle after a hard drive?
    Jun 2008
    mga bro, thanks for your help. Will check out Speedlab sa QC Ave. RION: yes maasuk siya and no power.
    Sep 2006
    By the way, how did you know that your turbo is kaput?
    We have a lot of experience with Kia Carnival. Most often, black smoke / low power is due to faulty injectors.
    Jun 2008
    exactly, black smoke and low power. had a couple of mechanics look at it and thats what they said, turbo.
    may point talaga si DD, kahit kasi walang turbo, may power parin dapat. unless the turbines are jammed...
    did they atleast remove the (turbo-out-intake-in) pipe? and had it revolution before they conclude sa turbo?
    Sep 2006
    Check boost pressure. If boost is present, turbo is functional.
    You may have to look into the injectors.
turbo mechanic or surplus kia
