thanks for the reply V6dreamer.
finally solved the problem that has been bothering me for a very long time. Last Saturday out of curiosity, i opened up the panel tapat ng passenger seat where the evaporator and thermostatic switch is located. I discovered na yun palang wire that connects the thermoswitch is not soldered but was clipped simply by a bent piece of copper strip. Apparently pag naaalog nag-loloose and connection at namamatay ang compressor, kaya i have to constantly turn-off-on yung AC switch para makatsamba at mag-on uli. I had the wires soldered to the thermoswitch. Luckily, 2 days na ngayon na normal ang automatic cycling.
Kicking myself right now thinking back that i have spent much for 2 repairs already and the problem is simply a loose connection
