Results 51 to 58 of 58
October 28th, 2010 01:01 PM #51
It should be possible with the right turbo to sit at around 130-150 hp and have no issues with the stock clutch and little problem with fuel economy... just select a turbine that spools up at higher engine speeds (around 3000 rpm and up) so you can leave fuel mapping nearly stock at low rpms.
For an Avanza to perform, you'll want to lower it, give it better shocks and anti-roll bars, and widen the stance with new mags and tires.
Personally, I would just go with the 1.5 and call it a day... you could have a fast 1.3 for the cost of the 1.5, but it will still have the cruddy 1.3 interior. The 1.5's interior, on the other hand, is pretty nice.
- Dec 2005
- 52
October 28th, 2010 08:57 PM #52
- Dec 2005
- 52
October 28th, 2010 08:59 PM #53
October 29th, 2010 12:26 AM #54
November 2nd, 2010 02:00 PM #56
November 2nd, 2010 07:16 PM #57
November 2nd, 2010 08:14 PM #58
Yeah. Those things actually decrease grip because less rubber is in contact with the road. Would have been better if they instead used ribbing to drain water.
