Results 31 to 37 of 37
May 21st, 2010 09:05 AM #31
ya sir mahal sa rapide (peace mga rapide bros) sa gas station ka na lang ... just bring along with you na lang din materials mo para mas makamura ka pa...
like ung sinabi mo na P800 1 set ng NGK, mahal sya.
try this one
http://www.boschsparkplugs.net/default.asp?i=1_6
4 ung terminal nya instead ung regular na 1, meaning the probability to miss fire is lest. i just thought this is one of the reason why my FE got high..cheers
Just bought it Php190 per piece, baka may mas mura ka pang makukuhanan. Moreover, platinum na rin sya, mas matagal ang gamin din...napasobrahan na ako sa advertisement...
May 21st, 2010 09:24 AM #32
When you say tune-up may iaadjust ka ba? How about sa diesel? Change oil, fuel filter, air cleaner, oil filter lang kasi ang alam ko may iba pa be kelangan gawin bukod sa mga pinapalitan natin sa PMS.
May 21st, 2010 09:25 AM #33
When you say tune-up may iaadjust ka ba? How about sa diesel? Change oil, fuel filter, air cleaner, oil filter lang kasi ang alam ko may iba pa ba na kelangan gawin bukod sa mga pinapalitan natin sa PMS.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 21st, 2010 10:39 AM #34actually if stored correctly wala naman shelf life yung oil. you can use it safely a couple of years from now as long as hindi sya contaminated with water and dirt.
May 21st, 2010 10:47 AM #35
As long as normal ang fuel consumption (kaya mahalaga naka-monitor ito, hindi sa nagtitipid tayo ) better wag na "pagalaw" like valve clearance etc. Regular oil and filter change, air filter cleaning/change and fuel filter change. Then check for leaks, masaya na diesel fed engine mo.
May 26th, 2010 09:12 AM #36
- Nov 2003
- 3,849
May 26th, 2010 10:10 AM #37checkups of the belts, brakes etc lang naman. kung crdi yung engine i suggest don't touch the injectors.magkakatulo lang yan or some other problem if you have it touched by somebody na hindi marunong.
