Results 31 to 34 of 34
- Jul 2007
- 35
November 1st, 2007 06:20 PM #31so guys the verdict is to just have regular oil and filter change and use oil recommended by your car manufacturer.
Thanks for the insights. My kumpare is marketing an oil additive so I searched first to find out what experts here in the forum has to say about the use of additive. Lahat naman kasi tayo gustong makatipid sa gas consumption natin at mapahaba ang buhay ng engine at kotse natin.
Thanks again,
knight-rider
- Jul 2007
- 35
November 1st, 2007 06:29 PM #32hi guys i just found this article can u comment on this pls? or did any of you guys tried it? thanks again!
Finally, a fuel performance-enhancing additive that works for the pocket and the environment
Now in the Philippines... a new, unique, exclusive eco-fuel saver that is a true technological breakthrough for significantly improving performance from gasoline, diesel or bio-diesel fuels, while reducing global-warming emissions.
Ultimate Mileage and Ecology Squared (Ultimate ME2) is a liquid fuel performance-enhancing additive that has been tested in a recognized independent laboratory (using United States Environmental Protection Agency, US-EPA, testing protocol SAE J1321 Type II) to dramatically reduce exhaust emissions and improve fuel efficiency from all types of internal combustion engines, including gasoline, diesel and 2-stroke engines. Ultimate ME2 is the only product in its league to be EPA-tested and proven to have desirable results both on mileage and exhaust emissions.
In the aspect of fuel economy, vehicles using Ultimate ME2 get better fuel economy with the lab tests showing 13 percent increase in mileage in gasoline engines and a 16 percent increase in diesel engines.
Ultimate ME2 is environmentally friendly, non-metallic and non-polluting. The ingredients of Ultimate ME2 contains only liquid compounds of hydrogen, oxygen, and carbon like the hydrocarbons in fuel itself. It breaks down the fuel molecules into finer particles (from longer to shorter chains). This creates a cooler, longer, more uniform and more complete combustion. This results in fewer emissions for the environment. In fact, the authoritative EPA 511 testing proved that Ultimate ME2 will result in 44% reduction in oxides of nitrogen emissions, 33% reduction in carbon monoxide and 7% reduction in hydrocarbon emissions.
Furthermore, while other similar fuel additives only work at times to clean the engine and cease to work once the engine is clean, Ultimate ME2 works even better over time, even with a clean engine.
With increased mileage translating to fuel conservation as well as reduced exhaust emissions, the Ultimate ME2 could definitely help the Philippines reach the acceptable standard for air pollution and contribute in alleviating global warming.
Local marketing firm Orientrends, Inc. got the exclusive right to market and distribute the product in the Philippines from US-based Essentially Yours Industries (International) Limited, an integrated marketing company offering an extensive line of cutting-edge, quality products in the following categories: nutritional supplements, water filtration and fuel additives.
EYI International President and CEO Dori James O’Neill has a great deal of experience in identifying and marketing environmentally beneficial products. In the early 1990’s, O’Neill identified and marketed an environmentally-friendly insecticide to the grain industry in China, Japan, North America and numerous European countries. The introduction of this product has helped reduce the amounts of residual pesticides found in stored grain throughout the world.
Dedicated and committed to introducing Ultimate ME2 to the Philippines, O’Neill is optimistic about the potential of this one-of-a kind, environmentally friendly, non-polluting, liquid fuel performance enhancing additive: “With the ever increasing concern over global warming and increasing pollution levels, Ultimate ME2 could definitely be part of the answer to dramatically reducing the ever increasing airborne pollution levels in Manila and other major Philippine cities.”
Hope to hear your opinion with regards to this article
November 2nd, 2007 10:49 PM #33
It just says that it was tested to EPA protocols, not tested by the EPA itself.
I'd view any "universal" additive skeptically, since the requirements of gasoline and diesel engines are quite different.
Some fuel additives apparently work for cars with dirty fuel systems or which are suffering from poor octane fuel... but on newer, well-maintained cars, differences are either very slight or completely un-noticeable.
FYI, there's a thread for fuel additives, too... just search for it. ;)
- Sep 2004
- 59
November 5th, 2007 08:10 PM #34Based on the Virgin Oil Analysis data I have read on BITOG, SM oils have less ZDDP or referred here as zinc.
The negative effect is if you are breaking in a new engine which is not using the roller follower on the valvetrain, premature wear may result. That is why some are using ZDDP and moly additives on this condition. Otherwise, SM oil is good to use.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
