Results 1 to 7 of 7
January 14th, 2009 06:36 PM #1
I had a problem with my toyota surf 1KZ-TE engine when i pressed the accelerator the Tachometer does not increase more than 2000 even though you will fully press the gas pedal ... the engine is running normal. Engine check light OFF. please help! thank you and more power!!!
THE AUTO SPECIALIST
- Mar 2006
- 607
January 14th, 2009 10:11 PM #2kailangan diyan scanner para makita ang live engine data kung nag receive ng rpm signal para may comparisson
- Sep 2006
- 1,335
January 16th, 2009 09:22 AM #4Normal ba ang true engine speed? Tachometer indication ba ang problem?
January 16th, 2009 09:25 AM #5
a/t ba yan?
is your kickdown cable still attached? it is a cable wrapped in orange rubber connected via acceleration cable > fuel pump > a/t
January 17th, 2009 02:43 PM #6
Problem solve!!!! Salamat sa lahat!! culprit fuel line and injection pump strainer clog!!!!!
- Sep 2006
- 1,335
January 18th, 2009 12:41 AM #7Salamat sa pag post ng "fix" mo. Great troubleshooting. Dami makikinabang dito. Sana tayong lahat ay nag popost kung paano na solve ang problema natin.
Magaling ang mekaniko mo.
Yes Yes squeaking sound is heard when shifting only
