Results 1 to 5 of 5
    May 2008
    Hello newbie lang po... anyone try Total engine oil like
    (Quartz 5000SM(20W501&5W40) feedback naman po
    tnx
    Jun 2006
    Total is one of the largest oil companies in the world. I think they are the 4th largest.
    I have not used their oils, but I use their ATF. So far its been good.
    before maggamit ng oil ng total check mo muna API rating kasi meron sa silang promo change oil less than 600pesos tapos check ko ang oil API SG lang. check mo rin manual mo baka hindi compatiable
    Jun 2006
    Quote Originally Posted by raine View Post
    Wow SG obsolete na yan. pang 1993 and older engines yan.
    Current API ratings are SJ, SL and SM. You can use SL and SM in any gas engine. SJ is for 2001 and older engines.
    http://www.aa1car.com/library/API_ratings.pdf
    Nov 2003
    the rating of the oil and the viscosity are what you should look at before using it. choose the right one for both those things.
Total Oil lubricant anyone try it
