Results 21 to 30 of 34
- Jan 2008
- 380
April 29th, 2008 01:06 PM #21...To 'speedyfix', yes I will do the same, at yan ang bentahe... Well, it's actually a rhetoric question though to emphasize something especially to those who wander between a 'top engine job', 'low engine job', or both.
If it is not too much, I intend to elaborate more on the compression and leak down tests, and some reasons why a 'low engine or full engine job is needed or preferable', at least from a co-carowner's point of view.
April 29th, 2008 08:43 PM #22
[QUOTE=1D4LV;1062298]question lang. sa utol ko ito (hindi ito sa akin....)
car is Mazda Familia 96 GLXi.
the car kasi excessively emits black smoke. Tapos parang wala na syang power in acceleration. In fact, parang namamatay yung engine at 2nd gear pag umaahon sa humps."
She might not need to overhaul. Black smoke can be caused by clogged filters or over delivery of fuel. Excessive and constant white smoke is where an overhaul is in order.
- Apr 2008
- 9
April 30th, 2008 04:59 AM #23Talking from personal experience sa top overhaul:
Pina-dukot ko yung makina ng corolla ko which showed almost the exact same symptoms. Afterwards nawala yung problema for 3 months tapos unti-unti bumabalik yung symptoms ulit.
Suggestion ko is kung ibebenta na yung car ng utol mo pa-dukot mo na lang kasi di mo talaga mababawi yung gastos ng overhaul sa mazda, but if gagamitin pa siya for more than 6 months, pa overhaul mo na lang para bawas ang sakit sa ulo.
April 30th, 2008 05:20 PM #24
i'll update this thread.
talked to my sister earlier, she mentioned to me na tune-up and timing lang daw ginawa and the symptoms that i've talked about earlier here were all gone.
pwede pala ng ganun lang? hehehehehe.
anyway, i'll update this thread kung ano pa ang lumabas sa oto nya later.
April 30th, 2008 06:27 PM #25
serioso? tune up and timing belt can produce those symptoms?
something new sakin yun ha? o well mas ok kasi hindi laki gastos.
- Nov 2004
- 141
May 1st, 2008 07:44 AM #26yup. lalo na kung nag slip ang timing belt. kapag pinagtagal iyan, madadamay na ang ibang parte ng makina at kailangan na ng overhaul
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 04:43 PM #27timing belt ba or timing lang? those are 2 different things.
it's good that everything went away na because of that. just continue to monitor how the car is running and if anything else creeps up have it checked agad.
May 5th, 2008 09:13 AM #28
- Jan 2008
- 380
May 5th, 2008 10:20 AM #29Congrats. Dapat lang, di pa naman hukluban ang car, unless barubal masyado ang driver. Kung minsan mas lalo lang disgrasya pag pinabinuksan ang makina.
YUng black smoke maitim lang yan pero mas perwisyo ang puti at asul na usok.
- May 2008
- 13
May 9th, 2008 01:57 AM #30mga boss, hope you could help me with this...i had a problem with my car on transmission leaks at mejo mababa idling (namamatay ang makina if nag-brake/stop or may aircon).i went on a repair shop (di ko na sabihin kung saan) to fix the leaks on transmission (auto transmission - lancer 1994 model). i must admit na talagang konting konti lang alam ko about cars..they told me that they would do top overhaul din dahil may leak daw yung engine..so pina-go ko po..ang perception ko kasi pag ginawa ung overhaul, maayos yung engine problem ko tapos i-cover na daw lahat ng repair sa leaks (replace oil seals, timing belt, and the likes)..nakailang balik din ko sa shop dahil di pa din nawala leak sa transmission..naayos naman nila eventually yung leaks (to verify naglatag pa po ko ng sapin sa ilalim ng kotse hehe).kaso yung idling/engine problem (namamatayan) andun pa din..sa kamalasan nabangga din ko so pinaayos ko po yung hood and etc (ilang months after magpaayos ng leaks).then sabi sa akin nung tumingin parang patay daw isang valve ng makina..ang tanong ko lang po ngaun is kung pwede pa po kaya maresolve yung problema ko sa engine/idling?any suggestion po na shop for this one? (yung mejo makamura sana hehe..) mejo malapit din po sana sa workplace (makati) or sa bahay (mandaluyong). plano ko po pa-estimate muna sana. sayang nga e kung nalaman ko lang dati pa itong tsikot.com e di sana nabawasan gastos ko..hehe..mga boss, hoping you could reply to this po.maraming salamat po in advance..
chinchilla fur vest leatherjacketback
Verifpro - paypal, ebay, banks, crypto, docs and...
