mga boss, hope you could help me with this...i had a problem with my car on transmission leaks at mejo mababa idling (namamatay ang makina if nag-brake/stop or may aircon).i went on a repair shop (di ko na sabihin kung saan) to fix the leaks on transmission (auto transmission - lancer 1994 model). i must admit na talagang konting konti lang alam ko about cars..they told me that they would do top overhaul din dahil may leak daw yung engine..so pina-go ko po..ang perception ko kasi pag ginawa ung overhaul, maayos yung engine problem ko tapos i-cover na daw lahat ng repair sa leaks (replace oil seals, timing belt, and the likes)..nakailang balik din ko sa shop dahil di pa din nawala leak sa transmission..naayos naman nila eventually yung leaks (to verify naglatag pa po ko ng sapin sa ilalim ng kotse hehe).kaso yung idling/engine problem (namamatayan) andun pa din..sa kamalasan nabangga din ko so pinaayos ko po yung hood and etc (ilang months after magpaayos ng leaks).then sabi sa akin nung tumingin parang patay daw isang valve ng makina..ang tanong ko lang po ngaun is kung pwede pa po kaya maresolve yung problema ko sa engine/idling?any suggestion po na shop for this one? (yung mejo makamura sana hehe..) mejo malapit din po sana sa workplace (makati) or sa bahay (mandaluyong). plano ko po pa-estimate muna sana. sayang nga e kung nalaman ko lang dati pa itong tsikot.com e di sana nabawasan gastos ko..hehe..mga boss, hoping you could reply to this po.maraming salamat po in advance..
Just a moment... just checked my vin. mine not affected. i read somewhere 2018-2019...
Suzuki JIMNY [merged threads]
