Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
    #41
    even with a correct compression test, the most reliable test for combustion chambers integrity is the cylinder leakage test. this is done with the cylinder at top dead center compression stroke and compressed air is pushed into the spark plug hole through a cylinder leakage tester
    http://www.southbayriders.com/forums...hments/313840/ with each cylinder tested. while in the process, should there be loss of reference pressure, listen for noise of air escaping at the tail pipe, oil dipstick tube, oil filler cap, intake/throttle body and observe if the radiator coolant is bubbling. this will point as to whether there is compression loss and where or what was causing it
    Thank you sir.
    Jul 2015
    #42
    anybody can recommend casa or shops that offers top or general overhaul which offers reasonable price? Thanks.
    Jun 2005
    #43
    Quote Originally Posted by konichiwa888 View Post
    are you sure overhaul is required? assuming nag sludge nga engine mo, have you tried having the oil pan removed and cleaned the strainer?
    madami na cases that required only cleaning and dismantling the oil pan,scraping and cleaning out the gunk.
    have you done compression test on the engine?
    Mar 2015
    #44
    Shop near Lto p.tuazon cubao or home service pls.contact Domeng (0916) 331 7722 for schedule or visit. Hope this helps sir.
    Jul 2017
    #45
    Newbie here! Just need some opinions from you guys. I have a corolla xe 96 big body that just top overhauled recently. It was generally overhauled one and a half years ago. Ang nangyari ay bigla nalang tumigil ung car habang dina-drive ng pamangkin ko. Pina-tow nmin ung car hanagang sa talyer. Sabi ng mechanic kailangan daw i-top overhaul kasi nabali ang mga valves at rocker arms. Pinagtataka ko, hindi naman napatid ang timing belt bakit kaya tumigil ung car at nasira ung mga rocker arms at valve? Please share your opinion and thoughts po... Thanks in advance!
    May 2011
    #46
    Quote Originally Posted by bardzwin View Post
    First question
    What engine do you have?
    Second question
    How many miles has the car clocked?
    If your car has 4af series engine, it will not get damaged even if you cranked the engine without the timing belt.
    If your car is equipped with a 3e engine, the valve/s will collide with the Piston/s when the timing belt skipped or broke.
    Jul 2017
    #47
    Mga sir gandang hapon po! Sorry po newbie lng po pagdating sa sasakyan. I am driving a mazda 3 2004 model. Tanong lang po if may idea po kayo kung mgkano po mgpa top overhaul and san po kya may maaus na talyer at idea po kung magkano abutin? Recently po kasi nag overheat ung sasakyan ko and kala ko po dala lang ng leak sa water overflow reservoir which napalitan ko na po ngaun ng bago but still unti unti pa rin po nauubos ung tubig sa reservoir. Tapos po knina pag check ko po sa oil dipstick at engine oil cap may sludge po na prang kulay gatas po. Sabi po ng friend ko bka may tama na daw head gasket ko. Sana po matulungan nyo ko. Mejo tight din na po kasi budget ko.
    Ask na rin po sana ako if safe pa po ba idrive ito? Right now po ngsstart na po ako mgipon ng pera dahil ang sabi po sa akin maghanda na daw ako ng budget at mahal daw po mgpa top overhaul... please po tulungan nyo po ako.... salamat po
    Feb 2018
    #48
    Quote Originally Posted by rcdgreat View Post
    sorry newbie lng din po ako.. waiting for the answer if magkano po magpa top overhaul ngayon. Thanks in advance
    Mar 2018
    #49
    Hi guys! I have alterra 2006, nag overheat sya tapos ngayon namamatay pag nag inistart. Sabi sa CBV motors eh general overhaul na daw kasi namamatay na makina. Gusto ko lang malaman mga lodi kung accurate ba yung ganung assessment para mapagawa ko na din. Mahirap kasi ang overseas kailangan pa e utos eh. :-(
    #50
    Quote Originally Posted by Tomguts33 View Post
    It's too early to overhaul unless napabayaan ang maintenance ng makina. Pero overheat may be caused by radiator problem kasi tapos yung namamatay eh baka sa fuel injection system. Try to get a second opinion, dun sa mapagkakatiwalaan niyo na shop. Yung marunong sa modern CRDI injection system ha, hindi na kasi mechanical injection yang Alterra afaik.
    Berrima is a good shop imho. Search mo na lang sa net ang address nila if sa Manila ka.
Top Overhaul...
