Results 11 to 14 of 14
September 7th, 2009 04:05 PM #11
Mula 3K-H nung 70's, 4K nung 80's, 5K ng liteace, hanggang 7K ng FX, puro timing chain lahat. iisa lang ang block nila
September 8th, 2009 03:32 PM #12
Ask ko lang mga tsikot...Is revo vx200 1RZ-E engine is timing belt or chain?thanks..
September 14th, 2009 11:45 AM #14
The decision to replace is dictated by factors such as noise, and bad ignition timing. Usually you change the chains, the gears, tensioners, guides, etc. based on noise.
Changing any of the chains without changing the gears/
sprockets lead to faster chain wear for obvious reasons.
Re-using the old tensioners and guides simply does not make sense if one wants to minimize noise.
