Results 41 to 50 of 50
November 20th, 2008 02:18 PM #41
replace the bearing na din when you replace the timing belt para isang tirahan nalang. pag pinaghiwalay mo dodoble pa ang labor costs mo eh same area din lang naman yung gagawin. mas magastos.
- Jan 2008
- 29
November 20th, 2008 06:39 PM #42okay ito,madami ako natutunan...ask ko lang po kung kailangan ko na rin bang magpalit ng timing belt,pre-owned na yung nabili kong lancer,odo is almost 93k but after buying this car last february, i went to mitsubishi and pina-check up ko ang timing belt,sabi nila ok pa naman daw odo before was 86k....natatakot kasi ako na maputulan din ng timing belt kasi bumabiyahe ako from baguio to bataan twice a month...TIA
- Oct 2008
- 23
November 20th, 2008 06:43 PM #43ah ok....thanks. What about oil pan gasket na nagmomoist? Hayaan ko lang ba sya as long as walang leak? La sya kinalaman sa mga oil seals?
November 21st, 2008 04:10 AM #44
May 29th, 2009 01:08 PM #45
question po:
for tuneup/oil change na kasi ang 98 lancer ko. tapos due for replacement na din ang timing belt. pwede bang paghiwalayin ko muna sila or dapat sabay na talaga? ano ba dapat unahin? medyo tight ang budget eh. TIA!
- Apr 2008
- 537
May 29th, 2009 05:41 PM #46
ang pinaka priorty kung halimbawa kung may mga kelangan nang palitan yun ay ang timing belt mo kung halimbawa malapit na ito sa nirerequire na kilometer limit para palitan ito dahil kapag napatidan o naputulan ka ng timing belt malaki ang problemang kakaharapin mo at syempre kapag magpapalit ka na ng oil seals gaya ng overhead valve cover at O rings, oil pump, water pump at tensioner bearing.
puede mo naman isunod na lang ang change oil at i huli mo na lang ang tune up
May 30th, 2009 09:47 PM #47
To any CRV Gen 1 owner,
may nakagamit na ba ng ZWR brand of timing belt sa ride nyo? ok ba quality? half the price kse ng OEM belt. medyo tight budget ako pero if someone could give me good feedback might consider to have the ZWR instead.
appreciate your comments. thanks.
May 30th, 2009 10:13 PM #48
unitta yun brand na gamit ko sa honda ko dati afaik ito din OEM ng older models ng honda
- Dec 2006
- 35
March 29th, 2010 12:42 AM #49Good Pm mga sirs,
Kanina, parang may maingay sa makina ko, siguro timing belt na yun? pumipito siya. Nakakatakot yung tunog baka bigla bumigay makina. 94k++ na yung KM reading nya. nabili ko 2nd hand last last month.
ano ma suggest nyo mga master?
April 1st, 2010 03:45 PM #50
Hybrids and EV
