Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
    Aug 2003
    #41
    replace the bearing na din when you replace the timing belt para isang tirahan nalang. pag pinaghiwalay mo dodoble pa ang labor costs mo eh same area din lang naman yung gagawin. mas magastos.
    Jan 2008
    #42
    okay ito,madami ako natutunan...ask ko lang po kung kailangan ko na rin bang magpalit ng timing belt,pre-owned na yung nabili kong lancer,odo is almost 93k but after buying this car last february, i went to mitsubishi and pina-check up ko ang timing belt,sabi nila ok pa naman daw odo before was 86k....natatakot kasi ako na maputulan din ng timing belt kasi bumabiyahe ako from baguio to bataan twice a month...TIA
    Oct 2008
    #43
    ah ok....thanks. What about oil pan gasket na nagmomoist? Hayaan ko lang ba sya as long as walang leak? La sya kinalaman sa mga oil seals?
    Aug 2003
    #44
    Quote Originally Posted by sarceangel View Post
    hmmm... car's odometer is already past the 90K mark and it's a 2nd hand car.... if that was my car i would change the timing belt already just to be on the safe side.
    Dec 2008
    #45
    question po:
    for tuneup/oil change na kasi ang 98 lancer ko. tapos due for replacement na din ang timing belt. pwede bang paghiwalayin ko muna sila or dapat sabay na talaga? ano ba dapat unahin? medyo tight ang budget eh. TIA!
    Apr 2008
    #46
    Quote Originally Posted by arnarn View Post
    question po:
    ang pinaka priorty kung halimbawa kung may mga kelangan nang palitan yun ay ang timing belt mo kung halimbawa malapit na ito sa nirerequire na kilometer limit para palitan ito dahil kapag napatidan o naputulan ka ng timing belt malaki ang problemang kakaharapin mo at syempre kapag magpapalit ka na ng oil seals gaya ng overhead valve cover at O rings, oil pump, water pump at tensioner bearing.
    puede mo naman isunod na lang ang change oil at i huli mo na lang ang tune up
    May 2007
    #47
    To any CRV Gen 1 owner,
    may nakagamit na ba ng ZWR brand of timing belt sa ride nyo? ok ba quality? half the price kse ng OEM belt. medyo tight budget ako pero if someone could give me good feedback might consider to have the ZWR instead.
    appreciate your comments. thanks.
    #48
    unitta yun brand na gamit ko sa honda ko dati afaik ito din OEM ng older models ng honda
    #49
    Good Pm mga sirs,
    Kanina, parang may maingay sa makina ko, siguro timing belt na yun? pumipito siya. Nakakatakot yung tunog baka bigla bumigay makina. 94k++ na yung KM reading nya. nabili ko 2nd hand last last month.
    ano ma suggest nyo mga master?
    #50
    Quote Originally Posted by lui11 View Post
    Good Pm mga sirs,
    sir anong model ng sasakyan nyo?. ang alam ko every 80th kms kailangan na magpalit ng timing belt at tensoner bearing at mga oil seals yung water pump dipindi na lang kung mahina na..
Timing Belt Question
