Quote Originally Posted by mackkcam View Post
Hi,
I have some few questions in mind: (ride: Honda City ExI 1997)
Scenario, i need to replace my timing belt by next week and I dont know what should I and Where should I go with this, my mileage is calculating by next week it would be around 82k,
The Only Thing i Know is I need to replace my timing belt, but:
- do I still need to replace also all Fluids and if ever, lubrications?
or
- should i only stick with the timing belt replacement only??
and
- what are the other things that i should or inform the mechanic to check out?
help guys!!
Bro, much better if you change all the fluids, if you have extra budget, isama mo narin siguro lahat ng belts...para wala kana worry sa daan.
major replace
1.Timing Belt
2.Tensioner bearing
3.sabay mo narin ito palit:
-spark plug/air filter at change oil, sabay flushing narin
4.sabay narin re-timing.
KUNG may extra Budget ka;
1. all belts (excluding: seat belt ha)
2. High Tension wire(pa check mo muna baka pwede pa)
3. check all your hoses and clamps
4. brakes at clutch (pa bleading mo narin)tama ba term ko dun
KUNG sobra sobra sa budget
palitan muna clutch mo(clutch disk...etc...)pinaka mura na ok na clutch (FCC brand)
pag pinagawa mo lahat yan bro, sarap ng hatak niyan.
Good luck bro!balitaan mo ako!
