Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
    Sep 2005
    #41
    Speedyfix, question po: we have a Hyundai Grace but I was thinking of wrapping the headers with thermal wrap. Is it advisable? Will it reduce heat? The headers are cast iron and stock. If so, magkano and how long will it take to install? Salamat po sir!
    Aug 2004
    #42
    You don't need wrap on a stock manifold... the iron already absorbs the heat. But it wouldn't hurt (not much, at least).
    Sep 2005
    #43
    Ah ok. Thank niky! Pero will it help if I wrap it? Ang init pag long drive! Although hindi naman kasing init ng L-300 Diesel namin dati pero it's uncomfortable din. I also plan to cover the entire engine bay with DynaMat Xtreme. Mahal lang so I'm canvassing for a bulk pack para makatipid ng konti.
    Aug 2004
    #44
    Ah... okay... so this is to protect your derriere? ...yah, it should help a lot.
    The only problem is the issue of the iron eating itself underneath thermal wrap because the heat can't escape, supposedly, but on a stock engine which probably doesn't get revved a lot, it shouldn't be so bad.
    Sep 2005
    #45
    Yup! Hehehe! Salamat Kuya Niky!
    #46
    a friend of mine says you need to lessen engine wash kapag naka thermal wrap. i wasnt able to ask him why? totoo kaya?
    Nov 2003
    #47
    a 50ft roll of thermowrap is around 3500. labor will depend on how tight it is and how hard it is to get the header off. i'll need to see it muna siguro
    Aug 2007
    #48
    *niky: stock pa naman po yung headers ko..
    hmmm.. after reading the article posted by HyBrideVo nagdalawang isip ako hmmm.. ilang taon kaya magdeteriorate yung headers ko pag pinalagyan ko ng wrap?
    i read somewhere that if stock exhaust can last 50 years, exhaust wraps could deteriorate the exhaust down to 30 years...
    #49
    Quote Originally Posted by silver streak View Post
    I think worth it kung exact 30 yrs... matagal na yang 30 years.
thermal wrap o repipe???
