Results 1 to 6 of 6
    Jan 2011
    Hi guys, quick query lang...
    A mechanic suggested that I have my tappets adjusted because it's kinda noisy according to him.
    Question is : Is it really needed? Aside from making the engine noise dissappear? What if I didn't have it done, will the engine life decrease? Will it have any adverse effect to my engine?
    Actually I'm quite happy with the FC of my ESi, even though it's already 16 yrs old, I can get 10 - 11 kms/L, I'm just worried that there will be a change with my FC after having my tappets adjusted.
    Also, I am thinking that if it is not needed, then I'll spend the money on other maintenance stuffs instead.
    Share your opinions gurus,
    Thank you.
    Quote Originally Posted by r1chm0nd View Post
    Thank you.
    Yes kung maingay na puwede i-check yan for adjustment. How to Adjust Valves on a Four Cylinder Honda Car | Tech Articles
    DIY tappet adjustment
    make sure a reliable mechanic will do this.
    Jan 2011
    Sir Ry_Tower,
    What if I decide not to opt for adjustment? Will there be any ill effects to the life span of the engine?
    Sir Ry_Tower,
    AFAIK mas mababa yung FC mo kasi valve adjustment are needed to maintain the engine in tip top shape. Mura lang naman yan basta kaibiganin mo yung mekaniko!
    Jan 2011
    Need talaga to adjust ng tapet kapag kailangan, kase kung hindi mo maregular check yung clearance ng tapet, pwedeng mag hardstarting yan or hindi pino ang andar ng engine
    Jan 2011
    Sir Ry_Tower, how much po ba magpa adjust ng tappets based on your own experience?
Tappets Adjustment : Is it necessary?
