Results 31 to 40 of 51
- May 2010
- 30
June 25th, 2010 12:38 AM #31Thanks for all your help. Will try that soon. Not just yet since my wife will kill me if I leave early again to do stuff for my car. Di pa naman nnecessary. Medyo maingay lang. But will reserve having my exhaust done until I talk with one of the Sisons.
September 15th, 2010 08:21 PM #32
Sir, I noticed a crack or like a lit on my ga16dne muffler probably because of bakod humps na tumatama doon and I feel exhaust gas coming out from that crack/slit. It's underneath, along the centerline of the muffler. Based on this, the muffler became noisy and I'd like to silence it and I think having it repaired will do the job, will it not?
Also, if it was repaired or replaced I still plan to silence it more would replacing the resonator or the muffler with a bigger casing but same diameter (ID) affect anything? And when you said "exhaust note lower" does it mean "exhaust is bassy" or is it like a "low frequency sound."
Thanks!
September 16th, 2010 01:09 PM #33
Dear Kurby:
If the crack is just that - a simple crack then there is no problem having a welder patch it - it should work just fine.
But if the impact loosened the interior parts of your muffler then that's a different story - it will have to be opened and the inside repaired.
Ask a trusted welding/muffler shop to give you an assessment and quote - then you can decide.
As to the lower exhaust note - I mean exactly that - it will give off a sound that is lower in frequency - no musical comparison here just physics.
BTW if you did get a crack in you muffler then it's either mounted too low or you lowered your car too much.
The low mount is easy to fix - as to the lowered car well that's up to you, but in my experience here in the Philippines humps do not get smaller or potholes any shallower - the more ground clearance the better.
Best Regards,
Dusky Lim
September 16th, 2010 10:00 PM #34
Thanks duskylim.
The car is on stock height, with worn out rear shocks, however. The low mount probably is the problem, how do you fix it?
And yes its a crack but the exhaust also comes out of the crack.
Thanks!
I also have another question, whats a catback exhaust?
Thanks!
September 16th, 2010 10:30 PM #35
No brainer there, replace your worn shocks, its not just unstable, its downright dangerous.
A low-mounted exhaust pipe is simply adjusted higher by the muffler/welding shop.
I have no idea what a catback(?) exhaust is.
September 16th, 2010 10:38 PM #36
Alright, I'll just replace those as soon as I can.
Thanks Duskylim.
September 17th, 2010 11:28 AM #37
may catalytic converter muna bago dumaan sa muffler. more restriction and earth friendly kapag catback.
September 17th, 2010 12:45 PM #38
September 17th, 2010 01:55 PM #39
coz removing the catalytic converter is illegal
aren't you glad we don't have that regulation here?
we can drive around with headers and downpipe only
hehe
September 17th, 2010 06:18 PM #40
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
