Results 1 to 5 of 5
February 12th, 2007 02:56 PM #1
hi guys,
i just noticed parang may tagas yung engine ko and it looks like gasoline. it doesn't look like engine oil.
it's not as strong as tumutulo. pero basa yung engine. parang nahamugan. is this normal? if it is not, ano kaya ang problem?
thanks.
February 12th, 2007 04:02 PM #2
san yung tagas, sa ilalim? bat mo nasabing gas, pink?
kasi kung gas yan, mangangamoy.. baka other fluids mo yung tumatagas (gear oil/atf, steering fluid, engine oil, brake fluid/clutch, coolant, etc)
location / pics would help.. pwede mo ding pa check sa mechanic na agad para lang alam mo na.
February 12th, 2007 04:18 PM #3
sige i will be posting pictures. hindi siya pink. more of parang langis. you know the semi-gold, semi-transparent oil "manghihilots" use? dun siya sa bandang ilalim lang ng engine. hindi sa may mga spark plugs.
February 12th, 2007 05:55 PM #4
It doesn't look like oil? well, does it not feel like oil either???
sounds like an oil leak to me. Nahamogan? baka contaminated lang ng dumi yung leak...
Suzuki JIMNY [merged threads]
