Results 51 to 60 of 60
November 13th, 2003 11:53 AM #51
henry-sayang just had an intercooler passed off sa junk shop size nya was as big as a radiator for isuzu v10 engine. it came from a daewoo dump truck, the turbo cannot be serviced anymore.
November 13th, 2003 07:26 PM #52
If I opt to go on solid front axle anong kailangan ko at anong model brand ang maaring mabili na surplus.
thanks
November 13th, 2003 07:42 PM #53
Wag mong isipin kung san ka makakamura, ang isipin mo dapat kung anu-ano after market parts ang pwede idagdag sa diffs. Like for example, diff lockers, hindi lahat ng differentials pwede kabitan nito. So you better choose a donor which has more and cheaper parts to fill in. LC solid diffs, Patrol's, Samurai's and even Hilux Pick-ups can be a good donor, if you happen to find a pair.
Dapat kasi pareho ang final gear ng rear and front kung hindi, magkakaroon ng binding effect sa transfer case at ikakadali ng sira.
November 13th, 2003 10:57 PM #54
your best bet would be a hilux diffs, if LC40 they are not centered. sa hilux off center ang front only just like the configuration of the terrano transfer case. dont know lang if on the left or on the right ang transfer case output.
but if i were you stay with the stock terrano underchassis na lang. less modifications the better, less headaches to be encountered on the trail. and besides IFS front is not that bad off road.
- Dec 2010
- 3
December 1st, 2010 01:49 PM #55hi direct importer here, pwede rin po ako per container na po ang deal tnx
gigi 09178250698 09228250698 09386402298 tnx
- Nov 2010
- 14
December 1st, 2010 04:41 PM #56
- Nov 2010
- 14
December 1st, 2010 04:50 PM #57
- Dec 2010
- 3
December 2nd, 2010 11:20 AM #58kung marami po turbo chargers na kailangan nyo, pwede po ako padala sa next shipment ko
- Dec 2010
- 3
December 2nd, 2010 11:28 AM #59
- Sep 2021
- 3
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
