Results 31 to 40 of 60
October 5th, 2003 02:30 AM #31
sige hanap muna ako ng 6cylinders isang tanong pa ano iyong transfer case na dapat iconsider din sabi ni boss otep?
atsaka isa pa anong masasabi nyo sa mga makinang ito 4D31, 4d34 or 4be1
October 5th, 2003 12:27 PM #32
Mas maganda kung 'straight' ang set up mo. Meaning yung tranny, engine at axles ay galing sa iisang donor vehicle. Yung iba nga (like AMC Hammers) ay rebody ng donor vehicle (Nissan Patrol). So that most of the OEM settings are untouched.
Transfer case is yung tinatawag na 'dual'.
You should know kung saang donor vehicle galing ang components mo. And dapat alam mo OEM tire size ng vehicle na yun. And stay within 10% of that size (10% up or 10% down). Kung 31" tires naman ang gagamitin mo, malamang oks na iyan kasi common size naman ito.
October 6th, 2003 11:28 PM #33
boss otep/ungas
4DR5 engine ba pede ng pangsabak sa mga lugar na pinupuntahan ng mga offroad club?
October 7th, 2003 10:07 AM #34
qman, its not really the engine. Even a 70bhp Pajero can take trails as long as the suspension, tires and gearing are set up properly. It's just about knowing the limits and not going beyond them.
October 7th, 2003 03:28 PM #35
qman::: Pwede kahit na anong engine. Even gas powered units can drive the trails. Pagkakaalam ko Manila Offroaders use Chevy V6, yun nga lang di matched sa differentials kaya sira ang axles nila sa isang competition.
"You should be able to test your vehicles capability to know what upgrades you want next." quoted from Mr. Ken of Delta Recon.
Even bone stock vehicles can cope with the 4x4 trails that we encounter. Gear matching will be your essential tool to overcome difficult obstacles.
*edit:
Nalimutan ko post yung engine specs na tinanong mo, hehehe. :D
(engine model - manufacturer - hp/rpm - displacement)
4BA1 Isuzu 85/4000 2775
4BC2 Isuzu 100/3500 3268
4BD1 Isuzu 110/3856
4BD2 Isuzu 100/3268
4BE1 Isuzu 120/3636
4BG1 Isuzu 125/3856
4D32 Mitsubishi 110/3567
4D33 Mitsubishi 130/3200
4D56 Mitsubishi 72/4200 2477
4D56-Turbo Mitsubishi 84/4200 2477
4DR5 Mitsubishi 80/3700 2659
4FB1 Isuzu 61/5000 1817
4FG1 Isuzu 78/4300
- Nov 2002
- 27
October 7th, 2003 07:31 PM #36qman,
kung 4dr5 engine ang gagamitin mo tapos body/chassis na lang ang matitira sa rig mo. sa opinyon ko sayang lang. kung ako sa 'yo i-dispose mo na lang yan at bumili ka na lang ng mitsubishi willys jeep galing japan.
may mga alam akong mitsubishi jeeps na binebenta. ang mods na gagawin mo ay lift na lang with bigger tires, power steering to be a competent trail rig. the unit cost will range from 150K to 180K. compare these prices against the cost of your upgrade then decide.
- Nov 2002
- 27
October 7th, 2003 07:43 PM #37btw, 4dr5 din yung engine ng mitsu jeeps na sinasabi ko although may mga ibang engines(including 4dr5 turbo) na ginamit for these jeeps mas common dito yung 4dr5.
- Jul 2003
- 26
- 10,620
October 8th, 2003 12:42 PM #39isang pang mod is to have disc brake installed,
i remembered si olive drab after river crossing nung nag climb uphill nawalan siya ng preno.
November 2nd, 2003 07:45 PM #40
thank you sa lahat for information and suggestion.
finally got a td27 complete engine/tranny/differential
a complete donor from nissan terrano. just like sir ungas and otep said mas maganda nga ang complete donor dahil ikakakasa na lang.
and iyong sinabi ni kimpoy na mas maganda kung me disc brake, nasunod ko rin iyon.
my question is what is the biggest tire na pede kong ilagay doon, na di nakailangan ang regearing.
Im planning to power it up, i mean branded as much as possible ang ilalagay ko like the shocks and suspension. Nagtatanong tanong na ko kung saan ako makakabili nito at it is available sa Abu Dhabi UAE. Iwe weigh ko lang muna ang prices against dito sa pinas.
any other suggestion sa project kong ito.
thanks a lot?
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
