Results 1 to 11 of 11
    Oct 2008
    I use isuzu pick up LS 93model. kakachange oil ko lang ng zepsa, tapos mausok naman na white? suggest naman po kayo para hindi magging mausok ang sasakyan.thanks
    white smoke? di ba sobra diesel pag ganun?
    Pag black carbon deposit naman. put a garden hose on the tail pipe. pag puno na start the engine...
    http://www.dieselsmoke.com.au/
    hope this helps.
    worst case scenario yung may water contamination. so better have a good mechanic check you ride ASAP sir.
    Oct 2008
    hope this helps.
    Anung water contamination? you mean kailangan linisin ang sa radiator?
    Dec 2010
    gud pm... sir/madam... try nyo po ung aero wonder lube... engine treatment po cya... matatanggal po un maputing usok or maitim n usok n lumalabas na sasakyan nyo... trusted n po namin ito... isa sir/madam marami po cya benifits sa sasakyan... like makakasave po kau ng 20 to 25% ng gasulina or diesel pag gumagamit po kau nito at gaganda rin po ang hatak ng sasakyan nyo... if your interested just call or text me at this no. 0920607XXXX or 0916639XXXX... tnx po godbless.....
    Last edited by ghosthunter; April 22nd, 2011 at 08:25 PM. Reason: mobile phone numbers removed
    Oct 2008
    Quote Originally Posted by philipdavid17 View Post
    my warranty po ba ito? paanu kung lalong lumala at nasira pa ang makina.
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
    Read the rules.
    Ignorance of the rules is not an excuse.
    Repeat offenses will lead to banning.
    [/SIZE]
    Quote Originally Posted by robz02 View Post
    How is your air filter?
    Oil consumption? Madalas ka top off?
    How is your pcv/valve cover breather?
    Cold starts?
    Oct 2008
    Quote Originally Posted by 4JGtootsie View Post
    Cold starts?
    1.my air filter is new, and i tune when i change oil.
    2.naglalagay lang ako every 1month kasi nagbawas na e.in 1 week nkaka 4rides ako.
    3.i don't think so, siguro naman makikita yun pag nag tune up.
    4.cold starts. NO.
    Naghahalo na water sa oil mo and its being burned in the combustion chamber. usually headgasket ay bumigay na.
    Oct 2008
    paano po malalaman kung bumigay yung headgasket? para papacheck ko bukas sa mechanic.
Suggest some tips for not smoke belching?
