Results 11 to 15 of 15
- Jun 2005
- 113
July 11th, 2005 01:19 AM #11Originally Posted by badkuk
There are also other types like the rubber-sling type. There's also the fixed "socket" type that's specifically dimensioned for a specific filter diameter.
It is common knowledge to NEVER tighten an oil filter with a wrench. The wrench is exclusively for REMOVAL purposes only.
What I do when I hand-tight the oil filter is wrap it with a cleaner shop rag. The shop rag not only enhances the friction between the hand and the filter, but it also increases the effective diameter of the filter, thus making it easier for the hand to twist it in.
July 11th, 2005 01:33 AM #12
ah ganun ba? what if the filter is hard to grip, such as say, if the oil filter is difficult to access?
- Jun 2005
- 113
July 11th, 2005 01:41 AM #13Originally Posted by mbt
Nevertheless, if the oil filter is far too hidden, I would definitely resort to using a filter wrench for tightening... but I would also make sure to apply just about as much torque as I could if I were tightening it by hand.
July 11th, 2005 07:04 AM #14
The mechanic in a gas station near our house uses a wooden stick and a strip of abaca rope when removing oil filters.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 11th, 2005 12:20 PM #15hand tightening lang dapat... and use some oil on the rubber to make sure it seals properly.
3M Crystalline vs 3M Ceramic IR: Which is Best for Your Car? I think Crystalline might be...
