Results 1 to 15 of 15
    Aug 2003
    any suggestions on how to get the oil filter off an ae92? all those oil filter wrench crap don't work at all! ayoko sana magresort sa tuhog...
    baket hindi gumagana ang wrench?baka lang po mali ang paggamit....our mechanic never had problems with it naman kahit na sobrang sikip nang pagaklahigpit.
    Dec 2003
    either hindi nilagyan ng oil yung rubber part ng spout ng oil filter kaya nun nanigas at naluto yung filter, kumapit yung goma sa baka ng engine block, or replacement filter gamit mo at sobrang lambot yung kaha ng oil filter kaya pag ginamitan mo ng wrench either kadena or yung solid hook, lumulobog lang at hindi kumakapit yung wrench,
    kailangan talaga tuhogin yan, especially pag malambot yung oil filter at madali butasin yung filter
    Aug 2003
    glennsterr:baket hindi gumagana ang wrench?baka lang po mali ang paggamit....our mechanic never had problems with it naman kahit na sobrang sikip nang pagakahigpit.
    kamukha nito ung nagamit ko:
    Have you tried the fanbelt technique? Looping the fanbelt around the filter; make sure you loop it tightening more around the filter.
    If all else fails, tuhugin na nga yan, messy but it gets the job done.
    Jan 2003
    happened to me once sa fx ko. i did what Sir Ungas said the fanbelt technique but i wrapped a folded sand paper first sa filter then wrapped the fanbelt around it... and presto! tanggal ang filter hehehe... use rougher grit sand paper para mas may kapit
    May 2005
    Quote Originally Posted by Ungas
    mas prefer ko pa nga gamitin ang fan belt thing ..
    kaysa sa rather than wrench...mas nagamay lang cguro ako
    sure mo lang tightness mo para wla sablay
    sa wrench may tendency mabutas like what the some post sez
  8. #8
    so in tightening a oil filter, hand tighten lang ba? gaano kahigpit? since imposible naman sukatan ng torque wrench.
    May 2005
    Quote Originally Posted by ILuvDetailing
    hand tight lang ako bro .
    by means of feeling na lang sa higpit ..kung feel mo mahigpit na sia
    then double check ko na lang kung mag kakaroon the following day ng oil leak
    if ever meron tight na lang uli ..so far ok pa naman sa akin
    IMO
    kaya bang i-hand tighten ang oil filter? kailangan ata talaga gamitan ng tool yun (chain clamp or some such), kundi baka lumuwag pa at sumirit yung langis. kulang na kulang yung leverage ng kamay e hehe
    Jun 2005
    Quote Originally Posted by badkuk
    That's an effective filter wrench, as long as the size of the filter isn't beyond the useful range designed for the particular wrench you are using.
    There are also other types like the rubber-sling type. There's also the fixed "socket" type that's specifically dimensioned for a specific filter diameter.
    It is common knowledge to NEVER tighten an oil filter with a wrench. The wrench is exclusively for REMOVAL purposes only.
    What I do when I hand-tight the oil filter is wrap it with a cleaner shop rag. The shop rag not only enhances the friction between the hand and the filter, but it also increases the effective diameter of the filter, thus making it easier for the hand to twist it in.
    ah ganun ba? what if the filter is hard to grip, such as say, if the oil filter is difficult to access?
    Jun 2005
    Quote Originally Posted by mbt
    Personally, I've never encountered an oil filter that's too inaccessible for hand tightening or removal. I may have had to access it from beneath the car or at odd angles but they've always been accessible enough for hand-twisting.
    Nevertheless, if the oil filter is far too hidden, I would definitely resort to using a filter wrench for tightening... but I would also make sure to apply just about as much torque as I could if I were tightening it by hand.
    Aug 2003
    The mechanic in a gas station near our house uses a wooden stick and a strip of abaca rope when removing oil filters.
    Nov 2003
    hand tightening lang dapat... and use some oil on the rubber to make sure it seals properly.
stubborn oil filter
