Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 266
    guys,
    what do you think? what are the pros and cons of changing to performance filters? is it true na you have to change oil more often when using performance filters dahil mas madali daw makapasok yun dirty air?
    I'm planning kse to install simota on my ride. thx!
    got this from the simota homepage. ito ata yung mga pros.
    Increased Performance
    Simota Filters allow a higher velocity airflow. Better airflow means better breathing.
    Better breathing allows your engine to develop
    ... MORE POWER
    ... MORE TORQUE
    Low Restriction
    Multi layer design traps dust whilst still allowing air to pass through.
    Washable, Reusable Cotton Filter
    All Simota filters feature fully washable, reusable high quality cotton filters. The pleated design of Simota filters provides a greater surface area for filtration.
    Economical
    Less expensive in the long run because they are designed for years of use and reuse.
    cons are kelangan very religious ka sa cleaning nito kasi pwedeng marestrict yung flow of air pag madumi na causing loss of power and babagal ang hatak ng kotse.
    Feb 2003
    nod at ssaloon...
    i'm using simota myself for more than half a year na. pag naka 3 washings na, i plan to try k&n naman.
    definitely better than your stock air box
    Jan 1970
    approximately how many hp's gained thru this mod? talaga bang ramdam sya even on 1.3l engines?
    mas sulit yung HP gains mo if you couple your aftermarket air intake with after market pipings and exhaust systems e.g. performance headers, larger diameter exhaust pipes and a freeflow muffler.
    a good 8-10 hp gain siguro yan. although you wouldn't know the exact figure unless you have your car dynoed.
    may thread dito dati comparing the dyno figures of a car with simota vs k&n filters eh.
    Yung simota ko, hinigop ng turbo! Dati cone shaped siya, ngayon biglang naging korteng twirly cone!
    Im back to stock config, but am looking for a good hi flow drop in replacement. Kasi halatang humina accelleration ko.
    Aug 2015
    constant cleaning po ng simota filter kasi naka turbo ka, kaya yan nahigop ng turbo kasi clogged na yung filter....dalawa po ang function ng turbo, nag iinject yan ng air sa intake manifold thru compressor side at nag rerelease din ng excess burned gasses from your cylinder thru turbine side, so imagine ang turbo RPM is let say 100x faster than the engine RPM so hihigop yan ng malakas so yung clogged filter mo masisira, one thing more eh kapag clogged ang inlet filter mo tumataas ang exhaust temperature mo...
    from my experience:
    - better throttle response
    - redlines easily from mid range
    - improved fuel consumption by around .5km/L
    that is in tandem with a free flow muffler and a fuel pressure regulator though.
    sold my simota cone filter a few months back...im now back sa stock config...nakakabitin hatak..hehe..bibili ulit ako ng simota tom..hehe
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    oist! ako yata nakabili nun ha! d ko pa nagagamit caloyski!!! buy back mo na lang sa akin!!! hehehe...
    there were some discussions about this months ago... i think kung drop-in filter lang yung pinag-uusapan, you won't be seeing much gain in power (if any). the greatest advantage would be the fact that the filter can be reused for years
    you'll get bigger gains of a few hp if you change to a cone-type filter or something
    Jun 2012
    Oct 2008
    Posted this Oil Filter Comparison from GM truck central:
    Oil Filter Comparison Study - GM Truck Central
    at the Oil Filtration thread:
    http://tsikot.com/forums/engine-fuel.../index316.html
    and part of it is this study of Air Filter Comparison:
    Air Filter Comparison Study - GM Truck Central
    Another generous community there
    Substance
    Sep 2013
    papalagay ako nyan
    Sep 2013
    simota air intake
    Jan 2014
    hmm masubukan nga iyang simota na iyan, balak ko kase i upgrade exhaust system to include air filter intake. hindi kaya maka apekto yaan sa takbo gaya halimbawa pag mag arangkada odie kaya during shifting ng gear hindi kaya mabitin pag ganun yaan?
    Aug 2013
    High flow filters like K&N, Simota, etc, IMO, are not for daily driven cars. Sacrificed ang filtration, maganda lang sound pag accelerate pero very small ang gain. You have to get it very dirty for it to be efficient. Tama lang siya sa racing.
    same with mazdamazda
    -better throttle response
    -improved my fuel economy (kahit panay hataw ko...bilis tuloy dumumi fully syn na langis ko...nagpalit agad ako after 8500 km dahil nawala na yung smooth acceleration...balik ulit ako sa Havoline Energy Synthetic ayun hataw na naman kapag may chance ehehe)
    Jan 1970
    my car is 1.3 lumakas lalo acceleration, responsive, tipid sa gas, increased hp
    mazdamazda,
    nyek!sayang!nakapag-order nako sa fernandos e...tom na kabit..alukin mo kaya sa board natin..kung tom wala pa sa fernandos, sige,buy back ko
stock air filter vs. simota or K&N
