Results 111 to 120 of 266
- Nov 2008
- 43
August 13th, 2009 07:31 PM #112Newbie question meron po ba K&N na air filter for a 97 gli na corolla? Base kse sa mga post dito K&N is much expensive than simota pero in the long run ganun din yung magagastos mo. Noticeable po ba performance gain or like they said you need to change din exhaust and headers ba yun? Para may mag improve sya.
Thanks.
August 13th, 2009 07:52 PM #113
- Oct 2008
- 32
August 18th, 2009 03:16 AM #114I recently replace my stock intake with K&N cone type air filter. It cost me 4.5k. Mabigat sa bulsa but worth it talaga. Thumbs-up ako sa K&N. Ramdam ko improvement sa performance & I can easily reach 120+ km/h. Ganda pa tunog ng engine. DIY lang tubes ko. What I did is I used my stock flexible tubing then hanap ako 3" stainless tube na mga 4" long (got this idea from videos ng K&N sa youtube). Naglagay din ako heat shield with brackets galing sa stock ko. Di pa masyado tapos kasi re-paint ko pa sya ng black. Sensya na sa hi-temp na tape, temporary lang to will removed it pag na paint na.
Before:
After:
- Aug 2009
- 28
August 31st, 2009 08:48 AM #115ask lng po noob lng pag nagbuy po ako ng simota kasama na ung stainles tube or hnd pa po? kasi balak ko mag palagay ung may malaking tube tpos nka kabit ung filter sa dulo... and how much po kaya pag tube n filter?
August 31st, 2009 09:14 AM #116
August 31st, 2009 09:17 AM #117
- Aug 2009
- 28
August 31st, 2009 09:55 AM #118civic sir 99 model po car ko..
ibig sabahn po pag cnb ko na bble ako ng simota air filter ung filter lng ang bibigay sakn? eh anu brand po ba magnda pag yung tube lang kala ko kasi pag bumili ka simota air filter kasama na pati tube tpos papaltan mo nlng ng knn ung filter para magnda.
- Aug 2009
- 28
August 31st, 2009 10:06 AM #119edi kng bbili po ako kht tube nlng tpos k&n n deretso d na nid mag simota tama po ba?
or simota ang tatak ng tube na maganda?
kng bbuy po ako tube nsa magkano nmn po cguro kya?
pag ng palit ako ng air filter tube ang filter anu pa po nid palitan baka kasi magpapalit ako tpos may hnd ako npaltan gastos nnmn na di koa napagipunan pra cgurado po?
tyka po ung change oil sa engine nid ba palitan?
sensya na po noob lng bago lng me ngka car bgay skn tatay ko^^
August 31st, 2009 10:49 AM #120
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
