Quote Originally Posted by 4JGtootsie View Post
Begin with the fuel filter.
Check if its clogged or due for replacement. Hoses ang clamps should be air tight. Fuel pump gives consistent supply.
i'll go with sir 4JGtootsie's suggestion. update lang po, in my case it was a stuck o-ring where my idle cut off solenoid used to be. symptom used to be an intermettent idle, no idle,hard starting(bomba sa gas para mag-start), stalling in idle or on load under idle rpm. no problem on higher rpm cruise.
what happens is that during start and idle a busted o-ring is blocking the passageway of the idle circuit,hence, the problem - very much like a vacuum leak.
so my advice is don't neglect the basics and the obvious. g'luck!
