Results 1 to 13 of 13
    san ba nakakabili ng speed limiter and pwede ba install sa kahit anung car?
    Aug 2005
    speed limiter? afaik, you have speed limiter in your car. it's in the ECU which limits/controls your top speed.
    Aug 2005
    Pag sinabing limiter, speed limiter ba ito talaga or RPM limiter?
    im looking for speed limiter like or example you can only speed up until 40-50kmh. para pag auto pinahiram sa driver at hindi sya mag over speed/kumarera/kaskasero.. etc.
    Aug 2005
    speed limiter is totally different from a rev limiter.
    rev limiter = controls/limits engine rpm so you won't over rev when you hit redline. most cars today have it too.
    Aug 2005
    Quote Originally Posted by ineedmorehp View Post
    Hmmm...you can probably just tweak the ECU to limit the speed. i am not sure if somebody sells 'em on the market though
    Aug 2005
    Quote Originally Posted by HyBrideVo View Post
    Thanks for the info. I did not know there are 2 kinds of limiters.
    Do you think that the Avanza have a rev limiter? My wife is restarting to learn how to drive. Napapapikit na lang ako pag lumalagpas siya sa 3K sometimes 4K rpm and some times in neutral (akala nya naka kambio pa siya).
    Aug 2004
    Modern cars usually have both a speed limiter and a rev limiter, but some only have a rev limiter.
    If the car is identical to its Japanese market version, it'll have a 180-185 km/h speed limiter. If not, it'll keep going till it reaches the limits of its power versus the drag it incurs at high speed, which is often between 170-190 km/h for small cars.... or, until it reaches the rev-limiter in top gear.
    If you want a good speed limiter for your wife, stick a block of wood under the gas pedal, one big enough to limit her to 1/3rd pedal travel. ;)
    When she asks why the pedal's so short, sabihin mo lang... recalibrated sa casa lang yun... :naughty2:
    Akala ko you will use it when you pit in for tires and fuel .
    Aug 2005
    Muntik na akong mahulog sa upuan ko sa kakatawa. :hysterical:
    Tomorrow Aug. 25, 3 week old pa lang ang baby Avanza namin.
    pwedeng imodify mo ang gas pedal attached ka ng bracket at stop bolt para hangaang doon na lang ang travel limit ng gas pedal at hindi na bibilis pa at ang stop bolt para sa adjustment kung hangang gaano kabilis ang gusto mo,
    Jul 2006
    This one
    Or this one
    Oct 2004
    How about connecting a switch to the throttle position sensor wiring to trigger early fuel cut? Say 1800rpm?
speed limiter
