Results 21 to 26 of 26
- Oct 2010
- 11
December 28th, 2010 08:52 AM #21FaFa PSI
FaFa Civic: Tried once sa speedlab kaso they dont have facility on site & they were to busy to assist me then. i was there 8AM!
FaFa Shiro: I have chart of compatible NGK & DENSO plugs on my B6 engine as well as fake plugs from orig! Ive been doing my homework for 4mos already & still cant find correct solution!
Thanks mga FaFa I think best solution right now is have my injectors cleaned. I found this topic though:
http://tsikot.yehey.com/forums/showt...t=72927&page=3
Kaso anlayo servitek las pinas...haays outing ine! W/in the week pag ala ako nakita maybe I'll try them
Wish me luck
- Jun 2005
- 3,774
December 28th, 2010 08:26 PM #22speedlab doesnt clean injectors. they just remove the fuel rail and outsource the cleaning to precision along roces ave. injector cleaning is not cheap though. inspetion of spray pattern is ar 300 per piece minimum of 4 pcs. if cleaning is required, be prepared to shell out 2000 per injector again minimum of 4 injectors. so 8k agad.
- Jan 2008
- 4,726
December 29th, 2010 12:35 AM #24mahal naman ng injector inspection at cleaning daig pa ata yung injector cleaning at calibration ng diesel engine..
yung spark plug can last up to 2 years yan as long as walang abnormal sa engine.. kung brown ang kulay ng tip after 5000kms ok pa yan at ang sunog maganda pa.. kung maitim eh may tama ang engine
December 29th, 2010 01:00 AM #25
- Oct 2010
- 11
December 29th, 2010 05:18 AM #262K...wooow ganun ba kamahal sa precision
Sa Central diesel Q.ave corner ng capitol med center only charge 330/injector X 4= 1320 petot lang. problema they don't disassemble from engine, you need to find a place to take it out then bring it to them! Kaya nga hanap ako place na all in one para di hassle!
this is their link: http://centraldiesel.com.ph/about
GRABE naman nagastos mo
Believe me aejhay for 4 mos using 4sets of plugs ive tried different brand of petrol!
chinchilla fur vest leatherjacketback
Verifpro - paypal, ebay, banks, crypto, docs and...
