Results 1 to 2 of 2
    Hi sirs,
    ano po kaya problem pag ganito? bigla nalang nung pag start ko ng auto sa umaga okay pa naman so umandar na ko tapos maya maya biglang umiilaw na yung fuel indicator sa dashboard.. nag on tpos maya maya off tapos on uli tapos maya maya off. so balik ako sa bahay at di ko na muna dinala yung auto. ang tanong. ano po kaya ang problem sa auto? meron pa namang gas siguro mga 600pesos worth pa rin yun ng XCS. fuel pump?
    thanks sa mga tsikotteers in advance.
    Quote Originally Posted by Haruto View Post
    Hi sirs,
    Hello Haruto,
    Check your owners manual. I'm not sure if it applies to your vehicle. But some vehicles have a water sensor in their fuel filter; and flashing fuel light means water in fuel. If that's the case, you might have to replace your filter and drain your tank.
    Before everything, check your owner's manual.
    Hope this helps.
    ISO4113
    *Jason
Fuel indicator lights up even if car has at least 1/3 gas  left on tank
