Results 41 to 48 of 48
- Oct 2015
- 99
May 29th, 2019 04:00 PM #41Sir thank you will take your advise pa check ko sa edmel.
May 30th, 2019 09:48 AM #42
No biggie. As yapoy said pa change oil mo muna and make sure na tama yung nilagay na oil for diesel engines. In the off chance na manipis na flushing oil or gasoline engine oil ang ginamit nung last oil change.
If malakas pa rin oil consumption saka mo na patingnan. If kelangan talaga overhaul decide if it is worth it or ibenta na lang bago lumakas yung usok.
- May 2011
- 481
June 1st, 2019 10:51 AM #43Contrary to most common assumption, the combustion chambers cannot be 100% leak free. The Pistons will have oil clearance, the Piston rings will have end gaps. There will always be blowby gases you like it or not. But there are standards as to how much blowby gases exist. As long as blowby gases are not excessive, it is expected.
diesel engine crankcase pressure - Google Search
- 52,700
June 1st, 2019 10:57 AM #44
- May 2011
- 481
June 1st, 2019 11:54 AM #45
June 1st, 2019 04:09 PM #46
- May 2011
- 481
June 1st, 2019 04:27 PM #47
With a cylinder compression test, the crankcase pressure would even be lower contradicting your argument.
Maybe better to clear any doubt a d not resort to guesswork, you can do cylinder leakage test. This test already compensated for pressure leakage dute to the piston ring end gaps and piston to bore oil clearance.
The compression test would be inconclusive.
June 1st, 2019 04:40 PM #48
